Hello, can we have more information ?
1 - The network is set on the RB and the AP is “dumb” and work only as bridge ?
2 - What is the ip of the RB in your set up ?
3 - From what you can’t ping ? PC to AP or RB to AP or both ?
If you ping 192.168.1.2 from the PC it work ?
Can you try giving another IP to the AP (something like 192.168.1.5 or another in the range of 192.168.1.3-254) and try the ping again ?
edit: the pc receive a IP by the DHCP in the same network as the AP ?
Pc obviously ping to the rb , i’ll try to change AP ip address but i’m sure there is something to doa about static route.
i’ m newbie about advanced network config .
