Unable to ping IP on another interface
I have set up static IPs on my Mikrotik hEX, set up a DHCP server, and connected my laptop. All is well. My laptop can ping other devices on the LAN (192.168.1.3, etc.) as well as the MT itself (192.168.1.1).
However, when I add an IP address on another interface, the laptop cannot ping that (in this case, cannot ping 169.254.101.2).
Am I missing something? The MT is freshly reset, and there are no firewall rules, etc. I expected it to just work.
  │Laptop              │                        │ Mikrotik                    │
  │ DHCP On            │LAN Port                │  All static IPs             │
  │ IP: 192.168.1.2/29 │◄──────────────────────►│                             │
  │ GW: 192.168.1.1/29 │                 ether2 │  ether2: 192.168.1.1/29     │
  └────────────────────┘                        │  ether3: 169.254.101.2/30   │
The routing table on the MikroTik is as one might expect for this configuration.
[admin@MikroTik] > /ip/route/print
Flags: D - DYNAMIC; A - ACTIVE; c - CONNECT, s - STATIC, o - OSPF
Columns: DST-ADDRESS, GATEWAY, DISTANCE
#     DST-ADDRESS         GATEWAY                      DISTANCE
  DAc 192.168.1.1/29      ether2                       0
  DAc 169.254.101.0/30    ether3                       0
[admin@MikroTik] >
I don’t buy the ether2 route table entry:
I expect it to look like:
DAc 192.168.1.0/29      ether2                       0
Take a look at corresponding
/ip address add network=
RouterOS CHR 7.11 example:
/ip address print
Columns: ADDRESS, NETWORK, INTERFACE
# ADDRESS           NETWORK       INTERFACE
0 192.168.45.1/24   192.168.45.0  brcont
1 192.168.41.15/24  192.168.41.0  bridge
2 192.168.40.15/24  192.168.40.0  ether2
3 192.168.44.15/24  192.168.44.0  ether3
4 192.168.42.15/24  192.168.42.0  ether4
5 192.168.43.15/24  192.168.43.0  ether5
/ip route print
0  As 0.0.0.0/0        192.168.41.1         1
  DAc 192.168.40.0/24  ether2               0
  DAc 192.168.41.0/24  bridge               0
  DAc 192.168.42.0/24  ether4               0
  DAc 192.168.43.0/24  ether5               0
  DAc 192.168.44.0/24  ether3               0
  DAc 192.168.45.0/24  brcont               0
All good now. I manually edited the entries for privacy; this is related to this other post: http://forum.mikrotik.com/t/static-routes-bgp-routers-can-ping-each-other-but-wont-pass-traffic-through-it-ingress-and-egress/169175/1
Secondly, I found the problem. There were nothing wrong with the MT config. It was that Windows (I tested only on a laptop before) did not play nicely with 169.254.. addresses.
Replacing all 169.254 addresses solved all issues, including the other post.
