Undefined variable: _ (underscore)
I’m using PHP Api class (http://wiki.mikrotik.com/wiki/API_PHP_class) and i’m still getting “Undefined variable: _” in function read().
The error occures randomly.
I tried get new version of PHP Api class (1.4). I made there one little modification:
Modified this:
if ($_ == "!done")
       $receiveddone = true;
to this:
if ($_ == "!done"){
}else{
	$receiveddone = false;
Because “Undefined variable: receiveddone” was thrown.
I’m getting pretty desperate with the “Undefined variable: _” error. Any googling wasn’t helpful.
Thanks in advance.
Rax
Try using the other client.
Also, regardless… you may want to upgrade PHP, 'cause it seems we’re talking about some older version that has socket problems.
line 301 change to :
if ((!$this->connected && !$STATUS[‘unread_bytes’]) || ($this->connected && !$STATUS[‘unread_bytes’] && (isset($receiveddone) && $receiveddone)))
should fix it.
