Why does Mikrotik use
/ interface bridge
add name = bridge priority = 0x1000
Is priority 1000 not good?
What does this priority 0x1000 stand for?
/ interface bridge
It is not 0x1000… the default is 0x8000
To properly configure STP in your network you need to understand the election process and which parameters are involved in which order. In RouterOS the root bridge will be elected based on the smallest priority and the smallest MAC address in this particular order:
Bridge priority (lowest)
Bridge MAC address (lowest)
Source:
https://wiki.mikrotik.com/wiki/Manual:Spanning_Tree_Protocol
Thanks for your reply
I will ask my question differently.
Why does Mikrotik use 0x8000 and not 8000?
Its just in hexadecimal format…
priority (integer: 0..65535 decimal format or 0x0000-0xffff hex format; Default: 32768 / 0x8000)
Ok, thanks for your clear answer.
