I’ve setup a 5Ghz link 5 miles out to a new tower site and am having some connection issues.
When I view Tower 2’ connection to Tower 3 signal I see the following values:
Signal Strength: -69dBm
Tx Signal Strength: -74dBm
Signal to Noise: 33dB
Tx/Rx CCQ: 25/100%
Virtually ALL hardware on this AP/Link site is brand-new;
LMR-400
Coaxial Surge
ARC 23dB flat panel 5Ghz
MMCX to NF pigtail
RB/333
XR5
Other Readings
“Wireless Tables > Interfaces > wlan1 > Status”
Overall Tx CCQ: 25%
Ack. Timeout: 71 us
Noise Floor: -102dBm
My current wireless configuration is:
0 R name="wlan1" mtu=1500 mac-address=00:15:6D:63:94:04 arp=enabled disable-running-check=no interface-type=Atheros AR5413 radio-name="Tower 2 <--> 3"
mode=ap-bridge ssid="GigaNetP2P" area="" frequency-mode=manual-txpower country=united states antenna-gain=0 frequency=5800 band=5ghz-turbo
scan-list=default rate-set=configured supported-rates-a/g=6Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=default
noise-floor-threshold=default periodic-calibration=default periodic-calibration-interval=60 burst-time=120 dfs-mode=none antenna-mode=ant-a
wds-mode=dynamic wds-default-bridge=Network wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=post-2.9.25 hide-ssid=no
security-profile=Network_WPA2_Profile disconnect-timeout=3s on-fail-retry-time=100ms hw-retries=4 preamble-mode=both compression=no allow-sharedkey=no
Prior to the above settings I tried 20Mhz & 10Mhz channel width but link reliability and throughput were very poor.
Why 40Mhz channel width is working better I am unsure but my bandwidth tests indicate a substantial increase of throughput capacity, when using 20Mhz channel width the most throughput I could expect would be 950Kbps and 10Mhz was shorter of that mark where-as 40Mhz is providing a stable 6MB throughput capacity.
What does CCQ pertain to and how would I use the readings to better troubleshoot the link to pinpoint which end is actually causing me problems.
Thanks for the help
Regards
