unexplained gap in traffic from upstream to downstream in small isp
hi all,
I just started a small ISP and the CCR1009 is load balancing dualWAN (so 1 port per upstream provider) and then one other port goes to a switch for everyone else. we only have 200mb total upstream bandwidth and we always notice a discrepancy between total upload/download of the 2 wan ports and the port going to the subscribers (ranges from 8-18mb which on a 200mb network is incredibly significant) we’ve run IP accounting and found some mysterious addresses inside the network which we’ve then blocked. we used torched and discovered several inquiries from one external IP to another external IP that arent ones we are using. I would assume this was just traffic bouncing off but then the “discrepancy” should be symettrical right? but the gap from upstream RX to downstream TX goes from 8-18mb the gap from upstream TX to downstream RX is 1-3mb
we’re really struggling here because not all of us are still well versed with Mikrotik, any help at all would be appreciated.
It is ddns amplification attack usually. Fix the firewall rules and implement general drop rule for all incoming connections from wan.
hi there!
i tried doing this, but nothing is being dropped and the gap still exists
add action=drop chain=forward comment=“Drop new connections from internet which are not dst-natted” connection-nat-state=!dstnat connection-state=new in-interface=WAN
How the input chain rules look like?
