Unifi Clients no IP address
Thanks for the answer.
I’ll try to describe my problem in more detail.
I have two buildings connected via the Wi-Fi bridge: Building A and Building B.
In Building A, the internet access is via a Unifi Cloud Gateway. This is also the DHCP server.
A Mikrotik antenna is connected to a switch here.
The IP address of the Cloud Gateway and the Mikrotik antenna is 192.168.2.x.
All devices in Building B that are connected via cable have the IP 192.168.2.x.
These all work without problems.
If a Wi-Fi network has the IP 192.168.2.x, it also works.
But I have multiple Wi-Fi networks.
For example, a guest Wi-Fi network has the IP address 192.168.99.x.
In Building A, it works without problems.
In building B, behind the Wi-Fi bridge, I can connect to the Wi-Fi, but I don’t get an IP address.
I hope I explained it clearly.
Boy, do I hate this deja-vu feeling:
@Technics1210
Do not take it the wrong way, but essentially you are believing in the divinatory powers of the forum members, which while usually very good, sometimes fall short due to technical problems (out of tune crystall balls, misplaced Tarots cards, this kind of things).
You are simply not providing any meaningful detail, at the very minimum you should detail (EXACTLY) how you have setup your VLAN(s) on your network AND post the current configuration of your Mikrotik device(s).
Instructions here:
Additionally, since this seems a not-so-simple network setup, a sketch of the network topology might help.
Bridges do not send IP addresses, DHCP servers do.
Do you run DHCP server on an interface inside of this VLAN?
# jul/15/2025 10:17:21 by RouterOS 6.49.19
# software id =
# model = RBLHGG-60ad
# serial number =
add admin-mac= auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] speed=100Mbps
/interface w60g
set [ find ] disabled=no mode=station-bridge name=wlan60-1 password=3bc0-3d08 \
    region=no-region-set ssid=MikroTik-1fe5a
add name=WAN
add name=LAN
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge comment=defconf interface=wlan60-1
add interface=wlan60-1 list=WAN
add interface=ether1 list=LAN
add address=192.168.2.26/24 comment=defconf interface=ether1 network=\
    192.168.2.0
add address=192.168.99.1/24 network=192.168.99.0
add address=192.168.10.1/24 network=192.168.10.0
set servers=192.168.2.1
add distance=1 gateway=192.168.2.1
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/system clock
A few notes:
The last two ip addresses go to which interfaces?
And the first one should probably be:
add address=192.168.2.26/24 comment=defconf interface=ether1 bridge network=
192.168.2.0
You have a bridge with two interfaces in it (ether1 and wlan60-1), the ip address should go to the “outer” element containing the other two.
You have a route set, but the device is setup as bridge/switch.
Yes, 192.168.2.26 is the IP address of one of the bridge’s antennas.
192.168.99.1/24 and 192.168.10.1/24 are the IP addresses of my VLANs. I set this up as a test, but unfortunately, it didn’t work.
The bridge should transmit the IP addresses of 192.168.2.x, 192.168.10.x, and 192.168.99.x.
But only 192.168.2.x is being transmitted.
How can I set this up?
As IlKa said, a bridge does NOT “transmit” addresses.
It may be reachable at a given address, i.e. have an address assigned to it.
If you changed the IP address settings as I suggested, now the bridge will have the address 192.168.2.26/24.
If you need it to have more addresses, you assign more of them, the two attempts you made are m00t because you did not specify to WHAT element (interface) the address should be assigned (interface=bridge).
The ether1 and wlan60-1 have lost their individuality the moment you added them to the bridge.
Also, this should be corrected for clarity:
But VLANs are an entirely different thing, you will need to create new VLAN interfaces.
sorry for the late reply.
I don’t quite understand what I’m supposed to set.
I’ve posted the two configurations for the bridge’s two antennas here.
Perhaps you have another idea.
Thx
AP with the IP 192.168.2.26
# jul/22/2025 21:29:43 by RouterOS 6.49.19
# software id =
# serial number =
/interface w60g
add name=WAN
add name=LAN
/user group
    192.168.2.0
/ip ssh
/system clock
Here the second AP with the adress: 192.168.2.25
# jul/22/2025 21:31:34 by RouterOS 6.49.12
# software id =
# serial number =
/interface w60g
set [ find ] disabled=no mode=bridge name=wlan60-1 password=3bc0-3d08 \
    put-stations-in-bridge=bridge region=no-region-set ssid=MikroTik-1fe5a
/interface w60g station
add mac-address=04:D6:AA:A3:A3:37 name=wlan60-station-1 parent=wlan60-1 \
    remote-address=04:D6:AA:AE:C9:6A
add name=WAN
add name=LAN
/user group
/interface detect-internet
set detect-interface-list=all
add interface=bridge list=LAN
add address=192.168.2.25/24 comment=defconf interface=ether1 network=\
    192.168.2.0
/ip ssh
/system clock
A device has NOT an IP address, one (or more) interfaces on it may have one.
Both the devices you posted the configuration of have the IP addresses assigned to ether1 ONLY, respectively 192.168.2.26 and 192.168.2.25.
BUT in both devices the ether1 is INSIDE a bridge.
On first device on the same bridge there is also the interface wlan60-1 (correct).
On the second there is NOT any other interface but ether1, you need to add one (it is not clear to me, since you have both a wlan60-1 and a wlan60-station-1 interfaces, what the intended role of the device is).
But a bridge with only one interface tends to produce “the sound of one hand”.
You should assign the IP to the bridge (and NOT to an interface in it).
You have to think that a bridge is like BORG:
https://en.wikipedia.org/wiki/Borg
the biological and technological distinctiveness of ether1 and wlan60-1 are now part of the bridge.
So. since these two entities (ether1 and wlan-60-1) are now merged into a single one (the bridge) this:
makes little sense, and - see earlier post - the bridge, which is the collective, should be added as LAN.
Then, on the second device you have internet detect enabled, see Rule #5:
