Hi There!
My name is Bernardo and recently have implemented MikroTik in all my network they have near 150 ADSL simultaneous connection on a level 5 running in a Pentium 4 based PC with 1Gb DDR. So really works fine, but got a little problemā¦
in some cases (very aleatory) some users (that have connected to a different DSLAM and different location) have this problem:
The connection bandwidth is go to zero, still there a few seconds (usually 10 or 20) and goes to the profile limit again (it happens in every profile, default, 512, 256, 1Mb, etc).
I have implemented PPPoE for connections, have path ping carefully implemented, queues for bandwidth management⦠and so much other beatiful mikrotikās tools.
Any one can help me with this problem?.. If need some details, please feel free to request me
Thanks in advance ![]()
I“m from La Plata too! ![]()
In Spanish
Creo que puedo escribir en espaƱol ya que nos entendemosā¦
Yo empezaria por lo facil, tirale ping al cliente continuamente y fijate que pasa cuando no tiene transferencia, o sea, ver si en ese momento se pierden paquetes.
Otra cosa, revisa el CCQ de la seƱal del AP, por lo menos debe ser mayor a 40 y el signal strength de -40 para arriba como para decir que es un enlace acetable. Aca en La Plata es un asco la banda de 2.4ghz, yo tengo -84 de noise floor, eso tambien puede influir, dependiendo del tipo de placa que usesā¦
Te dejo mi MSN por si queres que nos pongamos en contacto: viroslash@hotmail.com
In English:
Make ping continuously to the client and see what happened when you“re experimenting the problem.
If in this moment the link have a massive data lost, your problem should be in the wireless configuration.
Take a look at the data rates, TX Power (set it according to your minipci card), CCQ and Signal Strength
i think you missunderstood the question, coz he is not using wireless, but ADSL for last mile .
