Hi Team,
I’ve recently purchased a hex POE 5 port routeboard for home.
Have upgraded it to the latest stable Router OS.
I’ve setup a bridge to do layer 2 hardware switching. It works great for my wireless access point over tagged frames.
The problem is no untagged traffic is working. IT’s not picking up DHCP and even if I give my PC a static can’t ping the router.
Setup is like the below
Ether 5 = WAP - Is setup with Vlan IDs for Tagged frames - When connecting to this works great.
Ether 3 and 4 - PC’s (Access ports) , nothing works on these.
Judging on the articles I’ve read my config should work, I’m not sure why it does not. Should I log a support case with Mikrotik?
I have also tried disabling hardware offloading on these ports and using the strip VLAN id feature in the switch however the result was the same
Config below
add bridge=bridge-lan comment=defconf interface=ether2
add bridge=bridge-lan comment=defconf interface=ether3 pvid=192
add bridge=bridge-lan comment=defconf interface=ether4 pvid=172
add bridge=bridge-lan comment=defconf interface=ether5
/interface bridge vlan
add bridge=bridge-lan tagged=ether5,bridge-lan untagged=ether3 vlan-ids=
192
add bridge=bridge-lan tagged=ether5,bridge-lan untagged=ether4 vlan-ids=
172
add interface=ether1 list=WAN
add interface=bridge-lan list=LAN
add address=192.168.1.1/24 interface=vlan192-gaming network=192.168.1.0
add address=172.16.1.1/24 interface=vlan172-clients network=172.16.1.0
/ip dhcp-client
add disabled=no interface=ether1
add address=192.168.1.0/24 dns-server=8.8.8.8 gateway=192.168.1.1 netmask=24
add address=172.16.1.0/24 dns-server=8.8.8.8 gateway=172.16.1.1netmask=24
