# Update Hurricane Electric DDNS IPv4 address
:local ddnshost "some.host.name"
:local key "secret"
:local updatehost "dyn.dns.he.net"
:local outputfile ("HE_DDNS" . ".txt")
# Internal processing below...
:local ipv4addr
# Get WAN interface IP address
:set ipv4addr [/ip address get [/tool fetch url="http://myip.dnsomatic.com/" mode=http] address]
:set ipv4addr [:pick [:tostr $ipv4addr] 0 [:find [:tostr $ipv4addr] "/"]]
:log info ("Updating DDNS IPv4 address" . " Client IPv4 address to new IP " . $ipv4addr . "...")
/tool fetch url="http://$ddnshost:$key@$updatehost/nic/update?hostname=$ddnshost&myip=$ipv4addr" \
dst-path=$outputfile
:log info ([/file get ($outputfile) contents])
#/file remove ($outputfile)
The problem is my router WAN interface is using local IP, so my router need to read IP address from 3rd party site (I mentioned above on my script) but it doesn’t work, anyone has idea to fix this script?
I can fix the script, but I can’t test it, i do not have that service.
If you want test some scripts on terminal, put everytime all script between { } and put "" before “?”
If you put that on script or scheduler or wathever, remember to remove the "" before “?” !!!
:local ddnshost value="some.host.name";
:local key value="secret";
:local updatehost value="dyn.dns.he.net";
/tool fetch mode=http upload=no url="http://myip.dnsomatic.com/" keep-result=yes dst-path="myip.txt";
:delay delay-time=3s;
:local ipv4addr value=[/file get "myip.txt" value-name=contents];
/file remove "myip.txt";
:log info message=("Updating DDNS IPv4 address - Client IPv4 address to new IP ".$ipv4addr."...");
# I can not test this line, I do not have that service
/tool fetch mode=http upload=no keep-result=yes dst-path="hereply.txt" \
url=("http://".$ddnshost.":".$key."@".$updatehost."/nic/update\?hostname=".$ddnshost."&myip=".$ipv4addr);
:log info message=("Updating DDNS IPv4 address - Server reply: ".[/file get "hereply.txt" value-name=contents]);
/file remove "hereply.txt";
Hi again, thank you for your reply, I tried this script:
/tool fetch mode=http upload=no keep-result=yes dst-path="hereply.txt" url=("http://".$ddnshost.":".$key."@".$updatehost."/nic/update\?hostname=".$ddnshost."&myip=".$ipv4addr);
Run it on scheduler, but still not working.
And what do you mean by “I can not test this line, I do not have that service” ?
I fixed to be like this:
But same, still not working.
/tool fetch mode=http upload=no keep-result=yes dst-path="hereply.txt" url=("http://".$ddnshost.":".$key."@".$updatehost."/nic/update?hostname=".$ddnshost."&myip=".$ipv4addr);
However this script is working, but updating my LAN IP (because my router’s WAN interface is using LAN IP)
:local key "secret"
:local WANinterface "ether1-GTW"
:local ipv4addr
:set ipv4addr [/ip address get [/ip address find interface=$WANinterface] address]
:if ([:len $ipv4addr] = 0) do={
:log error ("Could not get IP for interface " . $WANinterface)
:error ("Could not get IP for interface " . $WANinterface)
I know this is an old thread, but since it’s the first result when googling for “mikrotik he.net ddns”, I thought it might be useful to share my version of the script which contains a few improvements:
Support for IPv6 (you’ll need to specify an interface and an IPv6 pool)
Error handling (i.e. when the IPv6 update fails, the IPv4 will still be published)
Does not write temporary files
Does not rely on an external service to determine the IP addresss
Here’s the script:
# RouterOS dynamic DNS Update Script for he.net
# make global to preserve IP and IPv6 address across script executions
:global ipddns
:global ipv6ddns
:local ddnshost "myhost.example.com"
:local ddnspass "MY_SECURE_PASSWORD"
:local waninterfacev4 "V4_INTERFACE_NAME" # Interface to retrieve WAN IPv4 address from (i.e. pppoe-out1)
:local waninterfacev6 "V6_INTERFACE_NAME" # Interface to retrieve WAN IPv6 address from (i.e. bridge1)
:local ipv6pool "YOUR_IP6_POOL" # Pool that IPv6 address needs to be part of
:local url "https://dyn.dns.he.net/nic/update"
:local ipfresh ""
:local ipv6fresh ""
:local ipv4error false
:local ipv6error false
:do {
# get current IP address from WAN interface
:set ipfresh [/ip address get [find where interface=$waninterfacev4] value-name=address]
# Check if ipfresh is empty
:if ($ipfresh = "") do={
:log error ("DDNS: Failed to get IP address from interface $waninterfacev4.")
:set ipv4error true
:if ([ :typeof $ipfresh ] = nil ) do={
:log error ("DDNS: No IP address on $waninterfacev4")
:set ipv4error true
} on-error={
:log error "DDNS: An error occurred while getting the current IP address from WAN interface."
:set ipv4error true
:do {
# get current IPv6 address from LAN interface
:set ipv6fresh [/ipv6/address get [find where from-pool="telekom-ipv6" interface=$waninterfacev6] address]
# Check if ipv6fresh is empty
:if ($ipv6fresh = "") do={
:log error ("DDNS: Failed to get IPv6 address from interface $waninterfacev6.")
:set ipv6error true
:if ([ :typeof $ipv6fresh ] = nil ) do={
:log error ("DDNS: No IPv6 address on $waninterfacev6")
:set ipv6error true
} on-error={
:log error "DDNS: An error occurred while getting the current IPv6 address from LAN interface."
:set ipv6error true
# extract the portion of the IP address before the last / character
:do {
:for i from=( [:len $ipfresh] - 1) to=0 do={
:if ( [:pick $ipfresh $i] = "/") do={
:set ipfresh [:pick $ipfresh 0 $i];
:for i from=( [:len $ipv6fresh] - 1) to=0 do={
:if ( [:pick $ipv6fresh $i] = "/") do={
:set ipv6fresh [:pick $ipv6fresh 0 $i];
} on-error={
:log error "DDNS: An error occurred while extracting the portion of the IP addresses."
:do {
# Check and update IPv4 address
:if ($ipv4error) do={
:log warning "DDNS: Skipping IPv4 update due to previous error."
} else {
:if ($ipddns = $ipfresh) do={
:log info ("DDNS: IP address is already up to date")
} else {
:log info ("DDNS: IP address has changed from $ipddns to $ipfresh, sending update...")
:local body "hostname=$ddnshost&password=$ddnspass&myip=$ipfresh"
:local result [/tool fetch mode=https output=user url=$url http-method=post http-data=$body as-value]
:if ($result->"status" != "finished") do={
:log error ("DDNS: Failed to send IPv4 update")
} else {
:log info ("DDNS: Response from server: " . $result->"data")
:if (([:find ($result->"data") "good"] = 0) or ([:find ($result->"data") "nochg"] = 0)) do={
:set ipddns $ipfresh
} on-error={
:log error "DDNS: An error occurred while checking and updating the IPv4 address."
:do {
# Check and update IPv6 address
:if ($ipv6error) do={
:log warning "DDNS: Skipping IPv6 update due to previous error."
} else {
:if ($ipv6ddns = $ipv6fresh) do={
:log info ("DDNS: IPv6 address is already up to date")
} else {
:log info ("DDNS: IPv6 address has changed from $ipv6ddns to $ipv6fresh, sending update...")
:local body "hostname=$ddnshost&password=$ddnspass&myip=$ipv6fresh"
:log error ("DDNS: Failed to send IPv6 update")
} else {
:set ipv6ddns $ipv6fresh
} on-error={
:log error "DDNS: An error occurred while checking and updating the IPv6 address."
