Hi!
We have two CCR1009-8G-1S-1+ running a ROS 6 branded by GoingSoft. After upgrading one of the devices to 7.21.4 we realised that many options in Winbox are missing, like there is no Interfaces, no System, … however via SSH all commands are available in the CLI fortunately.
Unfortunately downgrading RouterOS back to 6.49 doesn’t work, we are stuck on 7.21.4 with the limited menu in the Winbox.
How can we upgrade/reset/flash the branded CCRs to a fully working 7.21.4 and if possible a stock firmware from MikroTik instead of the branded firmware? Is Netinstall the way to go? We don’t want to brick the CCRs.
Here is the output of /system/resource showing the branding by GoingSoft:
/system/resource> print
uptime: 21m1s
version: 7.21.4 (long-term)
build-time: 2026-04-21 06:49:05
free-memory: 1670.1MiB
total-memory: 2048.0MiB
cpu: tilegx
cpu-count: 9
cpu-frequency: 1200MHz
cpu-load: 0%
free-hdd-space: 79.4MiB
total-hdd-space: 128.0MiB
write-sect-since-reboot: 248
write-sect-total: 248
bad-blocks: 0%
architecture-name: tile
board-name: CCR1009-8G-1S-1S+
platform: GoingSoft
Thank you.
