Hi all,
I’m getting always the same errors when I try to upgrade RB333 and RB600 directly with Dude server.
With RB532* and x86 systems I don’t get any errors and all works fine.
When I try to upgrade a RB333 (right click on device then upgrade choice) I get as choice only the x86 package downloaded under File and doesn’t appears any powerpc package downloaded.
If I try with Upgrade button I get the powerpc package downloaded as choice but when I choose a package nothing happens.
I noticed that Dude server only refers to architecture kind (i386) but doesn’t care package type (routeros-powerpc), I’m sorry if this isn’t true!!!
I’m using 3.0beta8 Dude version.
Has anyone the same problem?
Thanks all.
Stefano.
