hi
i have various versions of routeros on routerboards (different kinds of and i have about 500 of them active in network). is it possible to upgrade them all to 4.11 ? versions vary from 2.9 to 4.2
hi
Yes. However, the license changed between v3 and v4 so you have to use Winbox within 72 hours to upgrade the license.
thx for reply. i will take a look into dude. i wonder how i will import 500 routerboards into dude. if only by hand then it is waste of time
do i need to install dude package into mikrotiks befor upgrading ?
no, you don’t need the dude package on them
Dude can auto-discover devices of certain types, just try it.
ok program is ok.
i have tried exporting configuration and modyfying and . no success. i have 500 mikrotiks to add into dude and ther is no way i can do it automaticly.
i have added 400 device sections and changed that matches in
no success.
it is a shame that this program doesn’t have import functionality. at least verry simple one
we will treat that as a feature request, thanks for the idea
ok but can i edit backup.xml somehow to import those mikrotiks ?
No idea, officially it’s not supposed to work and there is no import function.
from where can I get a download of routerboard v3.2.
