Upgraded from a RouterBOARD 750G r3 to RB4011iGS+, migrated config, but my IPSEC tunnel doesn’t want to come up :(.
rtrA is the new RB4011. rtrB is an existing 750G. Logs show that rtrA creates the initial packet, sends it, rtrB receives it, processes, replies to rtrA. Reply reaches rtrA, is detected by packet sniffer but not registered by firewall or ipsec stack. Both routers have public, static IPs.
Has anyone else encountered anything similar? What next steps can I do to debug this? Any help appreciated :).
[rok@rtrA] /system routerboard> /system routerboard print
routerboard: yes
model: RB4011iGS+
revision: r2
serial-number: XXX
firmware-type: al2
factory-firmware: 6.45.9
current-firmware: 6.45.9
upgrade-firmware: 6.48.1
[rok@rtrA] /ip ipsec> export
# mar/15/2021 01:33:48 by RouterOS 6.48.1
# software id = 5ZRG-3PM4
# model = RB4011iGS+
# serial number = XXX
/ip ipsec peer
add address=BB.BBB.BBB.BBB/32 exchange-mode=ike2 name=rtrB
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048 dpd-interval=5m enc-algorithm=aes-256 hash-algorithm=sha256 name=profile_1
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256 enc-algorithms=aes-256-cbc pfs-group=modp2048
/ip ipsec identity
add my-id=fqdn:rtrA peer=rtrB secret=XXX
/ip ipsec policy
set 0 disabled=yes
add dst-address=10.X.X.0/24 peer=rtrB sa-dst-address=BB.BBB.BBB.BBB sa-src-address=0.0.0.0 src-address=10.YY.YY.0/24 tunnel=yes
[rok@rtrA] /ip firewall raw> /tool sniffer packet print
# TIME INTERFACE SRC-ADDRESS DST-ADDRESS IP-PROTOCOL SIZE CPU FP
0 7.052 WAN AA.AAA.AA.AAA:4500 BB.BBB.BBB.BBB:4500 udp 478 3 no
1 7.925 WAN BB.BBB.BBB.BBB:4500 AA.AAA.AA.AAA:4500 udp 470 1 no
2 12.058 WAN AA.AAA.AA.AAA:4500 BB.BBB.BBB.BBB:4500 udp 478 3 no
3 12.112 WAN BB.BBB.BBB.BBB:4500 AA.AAA.AA.AAA:4500 udp 470 1 no
4 17.064 WAN AA.AAA.AA.AAA:4500 BB.BBB.BBB.BBB:4500 udp 478 3 no
5 17.118 WAN BB.BBB.BBB.BBB:4500 AA.AAA.AA.AAA:4500 udp 470 1 no
6 22.059 WAN AA.AAA.AA.AAA:4500 BB.BBB.BBB.BBB:4500 udp 478 3 no
7 22.116 WAN BB.BBB.BBB.BBB:4500 AA.AAA.AA.AAA:4500 udp 470 1 no
[rok@rtrA] /ip firewall raw> /ip firewall raw print stats
# CHAIN ACTION BYTES PACKETS
0 D ;;; special dummy rule to show fasttrack counters
prerouting passthrough 177 028 927 163 150
1 prerouting accept 0 0
2 prerouting accept 115 256 402
[rok@rtrA] /ip firewall raw> print
chain=prerouting action=passthrough
1 chain=prerouting action=accept src-port=4500 dst-port=4500 protocol=udp src-address=BB.BBB.BBB.BBB
2 chain=prerouting action=accept src-address=BB.BBB.BBB.BBB
[rok@rtrA] /ip firewall raw> /log print where message~"received" or message~"sending"
01:04:52 ipsec,debug IPSEC: ===== sending 432 bytes from AA.AAA.AA.AAA[4500] to BB.BBB.BBB.BBB[4500]
01:04:57 ipsec,debug IPSEC: ===== sending 432 bytes from AA.AAA.AA.AAA[4500] to BB.BBB.BBB.BBB[4500]
01:05:02 ipsec,debug IPSEC: ===== sending 432 bytes from AA.AAA.AA.AAA[4500] to BB.BBB.BBB.BBB[4500]
01:05:17 ipsec,debug IPSEC: ===== sending 432 bytes from AA.AAA.AA.AAA[4500] to BB.BBB.BBB.BBB[4500]
[rok@rtrB] /ip ipsec statistics> /log print where message~"received" or message~"sending"
02:08:22 ipsec,debug IPSEC: ===== sending 424 bytes from BB.BBB.BBB.BBB[4500] to AA.AAA.AA.AAA[4500]
02:08:27 ipsec,debug IPSEC: ===== received 432 bytes from AA.AAA.AA.AAA[4500] to BB.BBB.BBB.BBB[4500]
02:08:27 ipsec,debug IPSEC: ===== sending 424 bytes from BB.BBB.BBB.BBB[4500] to AA.AAA.AA.AAA[4500]
02:08:32 ipsec,debug IPSEC: ===== received 432 bytes from AA.AAA.AA.AAA[4500] to BB.BBB.BBB.BBB[4500]
A misconfigured firewall at rtr A can cause this. Show the complete configuration export from rtr A (see the hint on anonymisation in my automatic signature below).
I can’t see anything wrong in your firewall rules, nor rp-filter=strict that can sometimes surprise.
So the next thing to come to my mind is that the packet sent by RtrB is fragmented as it travels to RtrA, and the second fragment gets dropped by some firewall on the way.
Since the UDP header is present only in the first fragment, the sniffer matching on port=4500 shows that fragment, whereas only reassembled packets reach the firewall.
You can verify this by sniffing into a file at RtrA and opening that file using Wireshark. If the More fragments bit in the Flags field of the IP header is set, this assumption gets confirmed.
How this could be related to a migration from a 750 to a 4011 is unclear to me, though.
The ipsec tunnel came up without changes to configurations so I think your assumptions about fragmented packets could be right - although I’m puzzled why ISPs would fragment/filter IKE packets and why did it manifest when I replaced the router. Might correlate with the power cycling of ISPs equipment.
In all this time, I was not able to reproduce the error condition. Don’t like the “automagically” solved problems as they might reappear without warning - but now I at least have some tips for capturing the traffic for analysis.
I’ve seen unrelated events to synchronize within tenths of second (not necessarily in networking), so I would not be surprised if something was wrong on the network path. Here, the window was longer, between the last establishment of the tunnel on the 750 and the first attempt with the 4011.
If that was the case, even the failed reassembly of fragmented packets may not have been the actual explanation.
