Upgrading RB941-2nD from 6.49.21 to 7.24.4 fails
I can't update my version is 6.49.21
Model RB941-2nD
Whar can i do?
The RB941-2nD has only 32MB of RAM, so upgrading it is not worthwhile.
MikroTik recommends at least 64MB of RAM for RouterOS 7.
A first step would be providing enough information to let us know what/how you were trying to upgrade, and what errors you got . . .
Online upgrade?
Upgrade via file upload? If so, what specific files did youtry to use?
etc.
I tried to upgrade it online via Winbox, but it said that there wasn't enough space. It needed 7.2 MB, while only 6.7 MB was available. I freed up some space, and the download started and then finished. The device rebooted, but the problem persists.
clear history
Netinstall. Had that error some time ago and Netinstall was the only way.
Only for the record:
RAM<>Storage
The hAP lite:
  • Size of RAM 32 MB
  • Storage size 16 MB
7.x - generally speaking - does run on a hAP lite, but the interface feels more sluggish than 6.x.
Cannot say if routing/bridging speed is affected.
This.
It can be done but that doesn't mean you should.
Stick with latest ROS6 to avoid other performance problems.
Last time I tried 7.5 or something on my hap lite. It did not feel only feel sluggish when navigating CLI menus, it also became unresponsive every few days and needed a power cycle. That was annoying. Went back to 6.x and forgot I had a hap lite. Definition of rock stable.
