Hi all
Let’s assume I have UPNP stuff enabled. Is there any way in RouterOS to see which ports are currently open/forwarded via UPNP?
Thanks in advance,
Losty
Hi all
Thanks in advance,
Losty
I remember when i was testing this feature that you can see automatic rules created by upnp in FIREWALL-NAT
https://www.grc.com/x/ne.dll?bh0bkyd2
Use the Shieldup tool to check port status.
Besides Port queries, Steve Gibson has other tests such as UPNP exposure.
As freemannnn stated, you can see the automatically created rules in Firewall/NAT, with the comment starting with “upnp”
If you do not see any such rules, go to IP/UPnP, disable the service, delete all your upnp interfaces and recreate them. Enable the service. See http://forum.mikrotik.com/t/solved-upnp-seems-not-working-with-pppoe/93802/1
Thanks for that info.
Hmm.. I checked Firewall → NAT, but no UPNP rules there. Is this realistic? I would expect some running Spotify or Tidal app or FireTV to have open some port here, does it?
I also disabled and re-enabled UPNP and interfaces as suggested in you link → still the same. Is there some service port (e.g. 1900/SSDP ?) I need to explicitly enable? Couldn’t find any particular setting for this. At least the firewall should already allow all traffic from the internal network to the router…
Spotify and Tidal should not be opening any ports. This us mostly used by programs that need inbound connections, not music services.
You can test your upnp with https://www.xldevelopment.net/upnpwiz.php ( https://www.virustotal.com/gui/file/817c2ac62b3fa4315d0129cf1117a22c771f3ffeadea01bc8e398d1579fb1a6d/detection )
The tool allows for test upnp rules creation on your router and it works with mikrotik.
Thanks for the hint. Unfortunately I have only some macs and linuxs around here, so couldn’t use UPNP Wizard (obviously Windows only), but googled a bit and found https://github.com/kaklakariada/portmapper should basically do the same but platform-independend and it also has extensive log output:
> java -jar portmapper-2.2.0.jar -add -externalPort 4321 -internalPort 4321 -protocol tcp
19:35:09.706 [main] INFO org.chris.portmapper.PortMapperCli - Creating router factory for class org.chris.portmapper.router.cling.ClingRouterFactory
19:35:09.711 [main] DEBUG org.chris.portmapper.PortMapperCli - Creating a new instance of the router factory class org.chris.portmapper.router.cling.ClingRouterFactory
19:35:09.734 [main] INFO org.chris.portmapper.PortMapperCli - Searching for routers...
19:35:09.734 [main] DEBUG o.c.p.r.cling.ClingRouterFactory - System property 'portmapper.locationUrl' not defined: discover routers automatically.
19:35:09.776 [main] INFO org.fourthline.cling.UpnpServiceImpl - >>> Starting UPnP service...
19:35:09.776 [main] INFO org.fourthline.cling.UpnpServiceImpl - Using configuration: org.fourthline.cling.DefaultUpnpServiceConfiguration
19:35:09.794 [main] INFO o.fourthline.cling.transport.Router - Creating Router: org.fourthline.cling.transport.RouterImpl
19:35:09.802 [main] INFO o.f.c.t.spi.MulticastReceiver - Creating wildcard socket (for receiving multicast datagrams) on port: 1900
19:35:09.808 [main] INFO o.f.c.t.spi.MulticastReceiver - Joining multicast group: /239.255.255.250:1900 on network interface: en0
19:35:09.837 [main] INFO o.f.cling.transport.spi.StreamServer - Created server (for receiving TCP streams) on: /10.41.42.112:62353
19:35:09.839 [main] INFO o.f.cling.transport.spi.DatagramIO - Creating bound socket (for datagram input/output) on: /10.41.42.112
19:35:09.846 [main] INFO org.fourthline.cling.UpnpServiceImpl - <<< UPnP service started successfully
19:35:09.846 [main] DEBUG o.c.p.r.cling.ClingRouterFactory - Start searching using upnp service
19:35:10.852 [cling-9] WARN o.f.c.p.RetrieveRemoteDescriptors - Could not hydrate device or its services from descriptor: (RemoteDevice) Identity: (RemoteDeviceIdentity) UDN: uuid:6f909190-31c2-4ff4-a819-ddd2badb0e38, Descriptor: http://10.41.42.5:49152/description.xml, Root: true
19:35:10.852 [cling-14] WARN o.f.c.p.RetrieveRemoteDescriptors - Could not hydrate device or its services from descriptor: (RemoteDevice) Identity: (RemoteDeviceIdentity) UDN: uuid:6f909190-31c2-4ff4-a819-ddd2badb0e38, Descriptor: http://10.41.42.5:49152/description.xml, Root: true
19:35:10.853 [cling-9] WARN o.f.c.p.RetrieveRemoteDescriptors - Cause was: org.fourthline.cling.model.types.InvalidValueException: Can't parse device type string (namespace/type/version): upnp:rootdevice
19:35:10.853 [cling-14] WARN o.f.c.p.RetrieveRemoteDescriptors - Cause was: org.fourthline.cling.model.types.InvalidValueException: Can't parse device type string (namespace/type/version): upnp:rootdevice
19:35:11.511 [cling-9] DEBUG o.c.p.r.cling.ClingRegistryListener - Found service of wrong type urn:schemas-upnp-org:device:fritzbox:1, expected urn:schemas-upnp-org:device:InternetGatewayDevice:1.
19:35:11.888 [cling-6] DEBUG o.c.p.r.cling.ClingRegistryListener - Found service of wrong type urn:schemas-upnp-org:device:avm-aha:1, expected urn:schemas-upnp-org:device:InternetGatewayDevice:1.
19:35:11.889 [cling-7] WARN o.f.c.p.RetrieveRemoteDescriptors - Could not hydrate device or its services from descriptor: (RemoteDevice) Identity: (RemoteDeviceIdentity) UDN: uuid:6f909190-31c2-4ff4-a819-ddd2badb0e38, Descriptor: http://10.41.42.5:49152/description.xml, Root: true
19:35:11.889 [cling-7] WARN o.f.c.p.RetrieveRemoteDescriptors - Cause was: org.fourthline.cling.model.types.InvalidValueException: Can't parse device type string (namespace/type/version): upnp:rootdevice
19:35:13.062 [cling-12] WARN o.f.c.p.RetrieveRemoteDescriptors - Could not hydrate device or its services from descriptor: (RemoteDevice) Identity: (RemoteDeviceIdentity) UDN: uuid:6f909190-31c2-4ff4-a819-ddd2badb0e38, Descriptor: http://10.41.42.5:49152/description.xml, Root: true
19:35:13.062 [cling-12] WARN o.f.c.p.RetrieveRemoteDescriptors - Cause was: org.fourthline.cling.model.types.InvalidValueException: Can't parse device type string (namespace/type/version): upnp:rootdevice
19:35:14.859 [main] DEBUG o.c.p.r.cling.ClingRouterFactory - Did not find a service after 5 seconds
19:35:14.859 [main] ERROR org.chris.portmapper.PortMapperCli - Found no router
19:35:14.859 [main] ERROR org.chris.portmapper.PortMapperCli - No router found: exit
He actually found some UPNP devices, but none of them being the Mikrotik Router (That FritzBox is just for SmartHome and Voip).
Internet should be provided by a Mikrotik CCR on 10.41.42.1, but obviously UPNP is not working then, correct?
Since I see multicast-magic going on here: do I need some special setting there? Generally multicast should be working - I remember setting this up for my TV service (which is still working fine).
