Hello Everybody,
Im facing issues with the UPS module. My UPS is connected to router via USB cable, port name is usbhid1. My problem is, that the communication between the UPS and the router stops refreshing data after few minutes. It even does not catch power outages (i pull out the UPS power cable from the socket, UPS works on battery, but RB keeps telling me that everythings fine, we are online). It`s pretty much useless this way.
When the connections frozen, I must disable and reenable the UPS in WinBox. Then it works for few minutes again. As a workaround ive written a script that checks the return values of the UPS module once a minute. If the values don`t chage for 3 minutes, i assume that the connection is frozen and disable / reenable the ups. This workaround works, but things should not work this way.
My question are: Is this a common issue, or there is some issue in my HW? Are there any additional settings, that can avoid this problem? Can this constant disabling / enabling do any harm to my RB or to my UPS? (it`s about 200 - 300 disables/enables per 24 hours).
Routerborad: RB3011UiAS, ROS 6.49.15
UPS: APC Back-UPS BX750MI
Thanx for any answers,
Keso
