It has come to our attention that a rogue botnet is currently scanning random public IP addresses to find open Winbox (8291) and WWW (80) ports, to exploit a vulnerability in the RouterOS www server that was patched more than a year ago (in RouterOS v6.38.5, march 2017).
Since all RouterOS devices offer free upgrades with just two clicks, we urge you to upgrade your devices with the “Check for updates” button, if you haven’t done so within the last year.
Your devices are safe if the port 80 is firewalled, or if you have upgraded to v6.38.5 or newer. If you are using our home access point devices with default configuration, they are firewalled from the factory, and you should also be safe, but please upgrade never the less.
The vulnerability in question was fixed in March 2017:
Current release chain:
What’s new in 6.38.5 (2017-Mar-09 11:32):
!) www - fixed http server vulnerability;
And also Bugfix release chain:
What’s new in 6.37.5 (2017-Mar-09 11:54):
Currently this botnet only spreads and scans. It doesn’t do anything else, but we still suggest to change your password and upgrade your firewall, just in case. Recommendations about securing your router: https://wiki.mikrotik.com/wiki/Manual:Securing_Your_Router
FAQ:
What is affected?
- Webfig with standard port 80 and no firewall rules
- Winbox has nothing to do with the vulnerability, Winbox port is only used by the scanners to identify MikroTik brand devices. Then it proceeds to exploit WEBFIG through port 80.
Am I safe?
If you upgraded your router in the last ~12 months, you are safe
If you had “ip service” “www” disabled: you are safe
If you had firewall configured for port “80”: you are safe
If you only had Hotspot in your LAN, but Webfig was not available: you are safe.
If you only had User Manager in your LAN, but Webfig was not available: you are safe.
If you had other Winbox port before this: you are safe from the scan, but not from the infection.
If you had “winbox” disabled, you are safe from the scan, not from the infection.
If you had “ip service” “allowed-from” set to specific network: you are safe if that network was not infected.
If you had “Webfig” visible to LAN network, you could be infected by an infected device in your LAN.
How to detect and cure?
- Upgrading to v6.38.5 or newer will remove the bad files, stop the infection and prevent anything similar in the future.
- If you upgrade device and you still see attempts to access Telnet from your network - run Tool/Torch and find out a source of the traffic. It will not be router itself, but another device in local network which also is affected and requires an upgrade.
P.S: some details about the operation of the botnet can be found here
