Another noob to the forum…
Let cut to the chase. I have a mikrotik rb951ui-2hnd router and a huaweie3531 usb modem. I have create they wifi and everything but some times when i login in the wifi with a device it opens up the usb settings page.
How can i avoid to user of the wifi dont entering in that page? and pls give easy steps to follow as i am a noob.
However, if you do this, you won’t be able to access modem’s web interface as well! To avoid that, you have disable that rule everytime before you want to log in, or add accepting rule BEFORE you put the above. Otherwise, you have to place accepting rule as first:
