Hi everybody,
Than you for your help already.
I’ve a RouterBoard mAP2nd , my goal is to configure it as a dumb switch, but I’m struggling to use ether1 as one of the switch port. (I would like to use its PoE capabilities)
I managed to configure the bridge as a DHCP client of my home router (192.168.9.0/24) and have network and internet connection shared through the bridged port (ether2).
WAN interface is deactivated, DHCP server is deactivated and ether1 is part of the bridged ports.
So far, so good ![]()
Where it goes wrong, it’s when I try to change the cable from ether2 to ether1 I lose the connection and it doesn’t get an IP as if the ether1 is not bridged. That’s sad because I would like to power the mAP2nD using PoE instead of the power adapter.
Any clues, hints, tips, tricks ? Maybe I missed something in the huge Mikrotik documentation that you may be able to pinpoint ![]()
# oct/30/2021 16:03:44 by RouterOS 6.49
# software id = HB9G-KBSZ
# model = RBmAP2nD
# serial number = DE4F0E97EE83
add admin-mac=2C:C8:1B:C0:6C:22 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-C06C24 wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add bridge=bridge comment=defconf interface=pwr-line1
add bridge=bridge interface=ether1
add comment=defconf disabled=yes interface=ether1 list=WAN
add interface=bridge list=WAN
/ip dhcp-client
add comment=defconf disabled=no interface=bridge
set allow-remote-requests=yes
/ip dns static
/system clock
set time-zone-name=Europe/Brussels
/tool mac-server
/tool mac-server mac-winbox
