user logoff option- using usermanager
Am faced with an issue, i can create a user using usermanager, am able to login using the user created, i can even logoff from the hotspot, problem is when i log off, the billing on the usermanager doesnt stop, it continues billing.. so if i bought a 2hrs account, after the first logging the a/c expires after 2 hrs regardless u log out or not.
Is there a way of having the stored duration option using the usermanager. .ie when i click on log off the billing stops and when i log back in again the billing continues, rather than having the single duration mode.
see http://forum.mikrotik.com/t/credit-time-when-it-starts-counting/16556/1
Thanks alot…
Thanks skillful for your help, though i have noticed that if i just use uptime am not able to add cost to that user, while credit time i can add the cost factor.
Is it possible to add cost when using uptime only, for billing purposes?
Thanks in advance
You can only add cost when setting up “credit time”.
In your case, just create credit time with unlimited time (i.e time=0) and cost. Create as many of them as you desire. Select the appropriate one to add cost when setting uptime.
