user manager configuration
I want to configure user manager on router board RB493 AH. I have instaled the usermanager package and try to access usermanager page, http://myroutr-IP/username. The login page display than I tried to login with the user n pwd at that time I got this error msg: Error 501: Not Implemented
Router os details is below:
Router OS version: 3.25
Router board: 493AH
Please help me to configure usermanager with hotspor server.
Rosan
Try correct address for User Manager Page: http://myroutr-IP/userman , instead of http://myroutr-IP/username .
If you installed User Manager package for the first time, then default username is “admin” with empty password.
Thanks for reply,
I had installed the user manager package successfully. After that try to connect the user manager page(http://myrouter-IP/username). The usermanager login page appear than I had input the username admin and blank passwd than press login after that I got the error massage “Error 501: Not Implemented”.
Connect to http://myrouter-ip/userman NOT http://myrouter-ip/username
See post by Girts above
thanks
