User Manager create Batch of Users and Print vouchers or csv
Hello, i have an old version of routerboard an usermanager. There is an checkbox to export new created users to csv when i create a batch of users.
Now i have a new Routerboard and the actually Version of Routeros and Usermanager, there is no such option.
What is the workflow to create (300) users and get an csv of the new created users to print my vouchers.
In the Users-List in Usermanager are staying the before created users together with the new greated…thats not possible to difference
Thanks for your help
Nobody an idea ??
How do the others print ther hotspot vouchers from the users that ar new generated ??
In the WIKI is the old version descripted, there i can set the checkbox and export the users directly…why is this option in the new version not possible any more ?
here is a screenshot from 6.32.4
this is the way i make vouchers for my customers.
Hello, yes, but you generate the csv or voucher from all your existing users and not only from that, you have new generated ???
You have to fill in on top some characters where you can identify the new added users.
I put always a Prefix on my account so I can Identify them.
Once identified you select only those you need.
is this still feasible in RouterOS 7? otherwise, how to perform this same function i.e., export and print multiple vouchers?
