l have RousterOS 4.9 install with hotspot on my PC . l’m trying to access user login page which is http://Router_IP/userman, is giving me Erro 404: Not Found.
Look in “/system package” to insure user manager is installed correctly and not disabled. If not installed, go to the download page and download the “All packages” file for your router model to your computer. Unzip. Upload the user-manager-xxx.npk package to the router. Reboot. The xxx’s will differ depending on the RouterBoard model and RouterOS version.
the user manager is installed. l will uninstall the current now but the question is, how do l upload new user-manager-xxx.npk ? Please l need the full process to do that.
If it is installed and not disabled, don’t remove it. There is something else incorrect then. Can you ping 10.10.1.1 from your computer on the LAN? Do you use dhcp to assign ips on your LAN or use static ips?
ADD: Just to insure there is no misunderstanding, the URL for your localnet is http://10.10.1.1/userman
I noticed there are two subnets assigned to LAN. Which ip is the hotspot? The 192.168.1.1 or 10.10.1.1?
/ip hotspot profile
What is ip in “hotspot-address”?
The only thing I have left to try is login to the hotspot and try the WAN ip address (your public ip). http://217.xx.xx.xx/userman
You might want to also remove the 192.168.1.1/24 assignment from LAN. With the hotspot on 10.10.1.1, it serves no purpose, or does it?
when tried http://10.10.1.1/userman, it will prompt for normal hotspot login page and after enter user & passwd for hotspot after login, it will Error 404: Not Found.
Webbox is working perfectly.
Or:
Can l downgrade the RouterOS to 3.30 and my license will still work for it?
