User with "almost" admin privileges
Can I create a user (better a group) with admin privileges except to read sensitive data (passwords in ppp, mail, etc) ??
tried policy=!sensitive?
@infabo is right, sensitive is the policy that allows it. Just note its not granular. So !sensitive does include perhaps "semi-sensitive" data like Wi-Fi "password", which you might not consider that sensitive. It one-size-fits-all with the policy scheme.
Another approach is "skins". While this is not a policy per se, if the UI is missing for an "almost admin" you likely prevent mistakes that an "almost" admin might make, without using the CLI, which may be enough a barrier... depending on your needs. So "skins" are more like the same category, but "almost policy".
oooops... I missed the "sensitive" option....
There is a list what is considered sensitive:
