Userman Tickets
Guys,
How can I generate 24pcs of tickets on 1 piece of A4 paper for users with userman?
than you
You could export the CSV file and then print your own…
Thanks for the response, but that is not too good as its add more work to person by redoing it on excel… why not if its work as antamedia hotspot or cafesuite tickets generation.
new user manager beta has the ability to print more tickets per page
okay! that is good, but how can i download the new userman or make use of it to my existing userman?
the new user manager will not keep your config, and it’s not very functional yet. only for testing. it’s an early beta version. it can be downloaded in the usermanager sectin of this forum
okay!, i will hold till is fully functional.
Thank you
Hi normis
I would like to confirm when would the fully functional userman gonna come out for multiple accounts genertion.
Thank you
Hi normis
Thank you
