Usernames and Passwords in XML code
Hi there
We are using MikroTik User Manager to process usernames and passwords for our Hotspot locations. To sell vouchers is for us a little bit out of date. We have made a solution where users can order time (1 hour, 3 hours , 12 hours, 1month). When they type there VISA card information they receive automatically a username and passwords.
Username and passwords are predefined and stored in a database.
But :confused: to store these usernames/passwords is a lot of work.
Is there a possibility to transfere/export these passwords and username in XML code?
This will be a big help :smiley:
Greetings
Arjan
Arjan,
it is not possible to generate xml files, you can only generate csv files.
you can open csv files using MS Excel or OpenOffice Calc and save it as xml.
Thanks for your answer!
But, how do I save them some .csv file ?
After I generate these username/passwords, they are displayed on my screen.
There is only a text like this:
“You can print this page, unneeded information will be hidden (see print preview)”
..followed by the generated username/passwords.
Greetings
Arjan
You can generate csv files on user menu, select required user and use at the bottom,
Generate > CSV file
Nope, must have a older version. Can’t see option “CSV file”
grrrrrrrr.
Can this be true?
Arjan
I do not have any problems with 2.9.42 version.
Please, install the latest version to the router, then
Users > View > Generate
