I should find everything in that file.
But users are missing! And also the default groups: full, read, write are missing.
There’s only a new group with his own skin.
Any idea?
Thank you very much.
Thank you, Lordkappa
in my experience the backup file is usable only in the same router where is generated, because it contains MAC addresses of that specific device.
To clone configuration from a router to another (same model, same ROS), I know only export / import system.
Any other solution?
Thank you
