Using mikrotik routerOS as radius server
Hi i’ve been looking at various tutorials but havent managed to get mikrotik to work as the radius server. I want to use radius instead of hotspot because not all devices support hotspot (test equipment, FPGAs, etc) and that hotspot if a timeout is set will mess up ongoing downloads and can cause a file to end up corrupted.
I have the usual network of just 1 LAN, and WAN but i also use mikrotik as a VPN server to connect to local services remotely instead of using port forwarding. I’d also like to use the radius functionality for this, DHCP for wire and wifi.
