I would like some suggestions on the route to follow on this evolving network to see best result. The client started off with one, then two, …links and now wants to run VOIP over the wireless. I am using RB433’s for ethernet to wireless in routing mode at this stage. The client has seven sites of which four sites are connected in a ring and the other three each connecting to one another and two of the ring sites respectively. I will be using RB450’s to connect all the RB433’s at each site so one gateway exist on each site and also use OSPF to sort out the routing. Is this the right approach? Must the RB433’s also be setup for OSPF or should they (RB433) be setup for bridging instead? If the RB433’s are setup for bridging, I must use WDS which will half my throughput??
If I am posting this in the wrong section, please let me know!!
