When I try to use restore on the clean (no config) RB2011UAS-2HnD-IN v.5.21 on the quick setup I get CPE instead of AP. How can I make sure that restore will do AP so I don’t have to go through the headache of reconfiguring? I tried using “compact export” but it get errors here and there because of default configuration that been changed.
WAN (gateway) Configuration:
gateway: sfp1 ether1 (renamed with extension ‘-gateway’);
firewall: enabled;
NAT: enabled;
DHCP Client: enabled;
LAN Configuration:
LAN Port: bridge-local;
switch group: ether6 (master), ether7, ether8, ether9, ether10
(renamed with extensions ‘-master-local’ and ‘-slave-local’)
LAN IP: 192.168.88.1;
DHCP Server: enabled;
