using routerboard sxt + tp-link router
hi my friends…happy new year for all…
any one have an idea how to set up the routerboard sxt so it give internet to the tp-link router and the tp-link can give the internet service to more than 2 labtops wireleslly..
lets give you more details..
the routerboard sxt connected with my access point (omini5ghz+groove) and the sxt connected with tp-link router
the mode of anennna (sxt ) is = station pseudobridge clone
the tp-link router uses pppoe server
is there a way i can set up the sxt so it recieves internet service from my access point and give it to the tp-link ..
by the way ..if i connect the sxt dircetly to the labtop .i will able to use internet ( using pppoe connection type
if i connect the sxt to the tp-link ( of course with wan port on it ) ..i will not be able use internet inspit i set up the settings of tp-link
correctlly
any one have an idea ..what is the wrong?
hi
it is very simple.
you must connect your sxt in bridge mode to the your access point.
now you must config your tp-link(WAN) in pppoe mode and set your user name and password of pppoe connection in tp-link.
now you must config your lan,set ip address and nat your lan with your WAN.
now you can config your WLAN for connect your laptop to tp-link.
after this,you able connect to internet from pppoe client in tp-link from your sxt bridge.
good luck.
you mean i have to choose the bridge mode of the following choices?
Dear,
Yes set the mode for SXT bridge and make bridge in SXT , add bridge and add port ( ether+ wlan) and give it address . and connected the Ethernet fro sxt to router TP-Link and set the configuration to PPoE .
Please check it and let me for any update , please fell free for ask .
