Hi, i’m using Freeradius in a Ubuntu Server, the default package for Freeradius have an old Mikrotik diccionary that don’t have even (relatively old) wireless comments.
They try to warn you that, if you modify the dictionary with the one offered by Mikrotik will not work.
# Do NOT follow their instructions and replace the dictionary
# in /etc/raddb with the one that they supply. It is NOT necessary.
# On top of that, the sample dictionary file they provide
# DOES NOT WORK. Do NOT use it.
Well, this is correct, but if we make some minor modifications we can use it without problems.
Here the modified dictionary file for Debian, you must place it in /usr/share/freeradius/dictionary.mikrotik (backup the old dictionary for more security)
# MikroTik vendor specific dictionary
# Copyright (C) MikroTikls, SIA
# You may freely redistribute and use this software or any part of it in source
# and/or binary forms, with or without modification for any purposes without
# limitations, provided that you respect the following statement:
# This software is provided 'AS IS' without a warranty of any kind, expressed or
# implied, including, but not limited to, the implied warranty of
# merchantability and fitness for a particular purpose. In no event shall
# MikroTikls SIA be liable for direct or indirect, incidental, consequential or
# other damages that may result from the use of this software, including, but
# not limited to, loss of data, time and (or) profits.
# $Id: dictionary.mikrotik,v 1.7 2011/11/25 08:00:00 normis Exp $
# MikroTik Attributes
VENDOR Mikrotik 14988
BEGIN-VENDOR Mikrotik
ATTRIBUTE Mikrotik-Recv-Limit 1 integer
ATTRIBUTE Mikrotik-Xmit-Limit 2 integer
ATTRIBUTE Mikrotik-Group 3 string
ATTRIBUTE Mikrotik-Wireless-Forward 4 integer
ATTRIBUTE Mikrotik-Wireless-Skip-Dot1x 5 integer
ATTRIBUTE Mikrotik-Wireless-Enc-Algo 6 integer
ATTRIBUTE Mikrotik-Wireless-Enc-Key 7 string
ATTRIBUTE Mikrotik-Rate-Limit 8 string
ATTRIBUTE Mikrotik-Realm 9 string
ATTRIBUTE Mikrotik-Host-IP 10 ipaddr
ATTRIBUTE Mikrotik-Mark-Id 11 string
ATTRIBUTE Mikrotik-Advertise-URL 12 string
ATTRIBUTE Mikrotik-Advertise-Interval 13 integer
ATTRIBUTE Mikrotik-Recv-Limit-Gigawords 14 integer
ATTRIBUTE Mikrotik-Xmit-Limit-Gigawords 15 integer
ATTRIBUTE Mikrotik-Wireless-PSK 16 string
ATTRIBUTE Mikrotik-Total-Limit 17 integer
ATTRIBUTE Mikrotik-Total-Limit-Gigawords 18 integer
ATTRIBUTE Mikrotik-Address-List 19 string
ATTRIBUTE Mikrotik-Wireless-MPKey 20 string
ATTRIBUTE Mikrotik-Wireless-Comment 21 string
ATTRIBUTE Mikrotik-Delegated-IPv6-Pool 22 string
# MikroTik Values
VALUE Mikrotik-Wireless-Enc-Algo No-encryption 0
VALUE Mikrotik-Wireless-Enc-Algo 40-bit-WEP 1
VALUE Mikrotik-Wireless-Enc-Algo 104-bit-WEP 2
VALUE Mikrotik-Wireless-Enc-Algo AES-CCM 3
VALUE Mikrotik-Wireless-Enc-Algo TKIP 4
END-VENDOR Mikrotik
I hope this can help someone and too save the time that I have wasted for make it work ![]()
