Can anybody help me abt how to use Webproxy feature of MikroTik through RB1000? Do i need any card to install ?
Regards,
a4ubd
Regards,
a4ubd
If you want Additional Cache drive, You can always use CF storage card
Additional cache? that mean i can already use the webproxy without CF card ?
Regards,
a4ubd
yes, but keep in mind that the RB1000 doesn’t have so much storage space, so it’s not good enough for cache. You could use it without cache, just for proxy.
If you want cache, install a CF card in the RB1000 and use that
I’ve additional memory module which i can use and make it to 1 GB. Will it work for cache?
a4ubd
hay you can used that enter on Storge and formating your card and set cach n this card
when you format card and set chach in secondry disk
finished
tell me about eny thing againe
good luck
