is there a way to see the utilization (CPU, memory,…) of my device via WinBox?
See tools - profile.
thx ![]()
a more detailed profile would be nice ![]()
more detailed like what??
Right. It would be. Also similar tool for memory is missing.
Ahhh, it’s possible to add the memory, uptime, date, cpu via the WinBox dashboard.
But I am used to have a detailed overview from my DLink DFL firewall. There was one information site on which I could see several relevant data (cpu, connections, bandwidth, and so on).
Well. The concept is different.
I think it takes getting used to. ![]()
thx ![]()
Also /tool graph where you can graph CPU and memory resources and traffic etc
Yeah, these graphs are nice but they need space on the internal file system.
When the storing to disk is disabled, will it be saved in memory?
What happens when the memory of my RB2011 gets quite full?
When 0.0.0.0/0 has access to the graphs I hope this setting does not override the firewall rules - if yes it would be bad - I will try. If I only want to see the graphs via WinBox this feature should be able to set up more specific.
When I activate the “storing on disk” in Graphing/Interface Rules or Ressource Rules, does the router save the data automatically on the stick instead of the internal memory?
I tried to log the interface statistics (without saving to disk). When will the logged data be removed? Although I deleted the rule I can see the loggin from the time when it was activated. Will it be gone when the router will be restarted?
The graphing data are stored to internal flash only and you cannot select the usb flash or memory card to store there instead.
thx ![]()
The saving on external memory would be nice feature!
For what can be the external USB memory used?
It would. As you are asking the same things in more threads I already gave you the answer.
thx ![]()
