I have access to 4 DHCP IP’s, is there some clever way to utilize all of those with RouterOS while only using 1 interface, (i.e one cable from the cable modem to the routerboard).
I know this is a more advanced feature not many router’s have. I think this was talked about implementing in pfsense, but i don’t know if anything came to fruition.
You need 4 different interfaces to get 4 dhcp addresses.
Alright that settles it, thanks mrz!
or 4 routers =)
actually it comes down to needing 4 unique mac addresses. You could run some meta routers and virtual ethernets.
I always wondered how come there is no virtual ethernet interface inside RouterOS. A second and third MAC address per interface. Without any virtual BS.
There is an entry for it in winbox, interfaces > + > virtual ethernet, but when adding it it says feature not implemented yet. something that has been in the making, or is it for something completely different?
it’s for Metarouter and KVM, I believe…
I can’t count the times I needed a second and third MAC address (virtual Ethernet) per port on a RouterBORD and on a x86 with RouterOS.
That WinBox item is used with Metarouter/KVM, yes.
I need a “Virtual Ethernet” interface without having to use a KVM.
You guys are saying it’s possible with Metarouters, however I can’t get it to work.
I’m receiving a public IP from my cable ISP through ether1-gateway. I added a Metarouter and created a Virtual interface for it.
I used the ether1-gateway as source for the virtual interface and setup the virtual interface of the Metarouter to request a DHCP address.
Just keeps searching for a DHCP ip, but doesn’t get one.
Am I doing anything stupid, or did I understand it wrong that multiple dynamic IP’s are possible with a Metarouter?
Thanks!
Use the sniffer to see your outgoing DHCP requests. If you see them, but you don’t see answers to them, its the DHCP server thats not giving it.
It’s an ISP DHCP - it uslualy is bound to the clients MAC and any additional MAC addresses are not given service. ![]()
Thanks for the tip, didn’t thought this would be a problem at my ISP, because I can just connect an other pc directly to the modem and I just get an other IP address, hoewever that’s not at the same time. Maybe it’s configured to only give out one ip at a time.
Tried to bind my virtual interface to the bridge, and it just got an IP address so there’s nothing wrong with the Metarouter.
Thanks for your help!
