Is not a bug.
Paste this on your device:
/ip dhcp-client set [find] use-peer-dns=no
/interface pppoe-client set [find] use-peer-dns=no
/interface ppp-client set [find] use-peer-dns=no
Is not a bug.
I must use peer DNS. But this bug on RB 2011UiAS repeat the same DNS on every rows that write “Dynamic Servers”.
Thanks for reply, I have check this problem only on mipsbe devices:
netinstall 6.15 without keep previous config with netinstalled routeros-mipsbe-6.15.npk
All devices, after configured SNMP must be rebooted for SNMP to work, other things works flawlessly.
we are working on the issue.
And again, is not a bug, check how many peer DNS your provider send to you.
Why I’m sure is not a bug?
Because I’m using 4 2011UiAS all with 6.15 (really one with 6.16rc10…) with dynamic dns, one with dhcp client, one with pppoe-client connected to mikrotik pppoe-server, one with pppoe-client by ADSL (the screenshot)
the 4th are at my home and I use ppp on 3G as backup.
And this bug never happen to me…
rextended:
Other detail: i have configured SNMP simpy paste this on new terminal, without using winbox GUI:
/snmp
set enabled=yes trap-community=public trap-target=0.0.0.0 trap-version=2
the 4th are at my home and I use ppp on 3G as backup.And this bug never happen to me…
do packet capture, maybe your auto-configuration sends you all these servers (with duplicates)
running /interface wireless spectral-history wlan1 or /interface wireless spectral-scan wlan1 on RB2011UAS-2HnD-IN 6.15 drops wireless connection and router stops broadcasting SSID until disabling and enabling wlan1 in winbox via ethernet connection.
It’s the normal behaviour, any scan of any type and tx stop completly.
littlebill:
did sstp for win7 clients ever get fixed? or disconnects on pptp when logged into winbox? this all broke after 6.7? anyone not seeing these issues anymore?
SSTP is broken for me. I use it on x86, RB493G and CCR-1009, get disconnect on larger amount of traffic/bandwith. CCR as VPN Concentrator? no way.
wonderful, support any comments on this?
I have lost the hope after 6.7.
The rewriting of MPPE and making “ppp” multicore broken all feature I use on my 4 RB1100AHx2 pppoe-servers.
Already signaled to support from 6.10 and never get the solution,
every official new version I try, every version I’m forced to netinstall again the 6.7…
I use 6.15 on all my network infrastructure, no problem.
“ppp” new package are the problem…
yes!, Yes!, YES!
Is like someone on next RouterOS 6.16rc11 like my ideas…
*) time - on routerboards, current time is saved in configuration on reboot
and on clock adjustment, and is used to set initial time after reboot;
http://forum.mikrotik.com/t/feature-request-time-date-startup-value-in-system-clock/78539/8
This time change sounds very good.
YEEEESSSS!!!
BUG FIXED: http://forum.mikrotik.com/t/v6-11-released/75450/1
STILL EXIST ON 6.15
rextended:
BUG SIGNALED FROM 6.10 AND STILL NOT FIXED???Opened another ticket for that: [Ticket#2014041566000226] 6.12 UNFIXED BUG: user-manager profile limitation
I wait again the fix on 6.16… I’m waiting the fix from 6.10…
SOLVED ON NEXT 6.16rc11
—>> MISSING THIS FIX ON CHANGELOG <<—
This bug on 6.16rc11 still present:
webfig can not create full working scripts:
http://forum.mikrotik.com/t/radius-server-not-working-in-2-8-11/127/1
yes!, Yes!, YES!
Is like someone on next RouterOS 6.16rc10 like my ideas…
and on clock adjustment, and is used to set initial time after reboot;http://forum.mikrotik.com/t/feature-request-time-date-startup-value-in-system-clock/78539/8
Very very helpful for scripting.
on 6.16rc11 I reboot the board 2011i2hpnd and the system not reboot, required netinstall for restore the system
I try again with 6.16rc12 …
The “wireless-fp” package seems stable.
When will you default include it as primary, in the standard update package?
I want to upgrade all my network without enable every station manually
When I reboot using system/reboot my working 2011UiAS-2HnD netinstalled (netinstall 6.15) with 6.16rc11 it go to one loop with etherboot…
This problem for me is fixed with netinstalled (netinstall 6.15) 6.16rc12, never hang whenn rebooted.
“Timekeeping” work perfecly…
When will you default include it as primary, in the standard update package?I want to upgrade all my network without enable every station manually
Abbi pazienza… lo puoi attivare (se hai già una versione con wireless-fp) quindi lanciare l’update senza riavviare.
Ci ho già aggiornato più della metà della rete, in questo modo, senza problemi.
Quello che promettono è vero: ha significativamente meno latenza sia in NV2 che in nstreme…
Non ho incontrato un minimo problema nell’update, tutte le macchine hanno seguito (nel corso del tempo) questa scaletta:
6.7->6.10->6.14+fp->6.15+fp
Posso chiederti, per curiosità, da quale zona d’Italia?
Sorry for the Italian.
