This is a bugfix release, solving issues related to upgrade from v5 to v6.14.
We have made some interesting new features, including the new “ip cloud” menu, and general release of CAPsMAN:
What’s new in 6.15 (2014-Jun-12 12:25):
*) fixed upgrade from v5 - on first boot all the optional packages were disabled;
*) fixed problem where sntp server could not be specified in winbox & webfig;
*) metarouter - make openwrt work on ppc metarouter again;
If you already run some RouterOS v6.x version, simply click “Check for updates” in QuickSet, Webfig or Winbox packages menu.
Normunds,
i notice the CAPsMAN will cause all the connected APs not working when the CAPsMAN is down, is there anyway the CAPs will copy the CAPsMAN configuration and store on it self ?
and, when can be CAPsMAN able to let all CAPs running on same channel with no interference to others ???
I notice the CAPsMAN will cause all the connected APs not working when the CAPsMAN is down, is there anyway the CAPs will copy the CAPsMAN configuration and store on it self ?
Thank you for the suggestion - we will think about those features.
I test the supout, backup [NOT ENCRYPTED], backup encrypted, export verbose and compact on that model:
RB411AH (6.14)
RB433AH (6.14)
RB2011UiAS-2HnD (6.15)
SXT Lite 5 (6.14)
RB1100AHx2 (6.7)
RB Metal 2SHPn (6.14)
RB Groove 52HPn (6.14)
after that I stop to try every model…
and then I conclude:
all the speed +/- is the same 2/3 sec for all type of backup/rsc, but supout.rif need from 20 to 40 sec to complete.
the slower are 6.7 on RB1100AHx2 (production machine with ~1500 users, ~400 by NAT, the other by Routing): 43 sec, the faster 6.15 on RB2011UiAS-2HnD (my office) 18 sec.
Really I never made supout.rif periodically, only when is needed, and measuring how time is needed for supout.rif is waste of time for me…
