I know that and i already did that before. I have changed all ether6 to sfp1 but it didn’t help.
For example if i ping 8.8.8.8 interface=ether6 from CCR it`s working but when i change all ethr6 to sfp1 and do same ping 8.8.8.8 interface=sfp1 i get timeouts.
I have tried each combination of the additional parameters:
no-defaults=yes and no-defaults=yes
skip-backup=yes and skip-backup=no
but without success.
i have also tried with a very simple, one line .rsc script file:
/system identity set name=xyz123
to see if i can get this very simple script to run, but without success.
I am sure i am doing something wrong, but have run out of ideas of what additional to try.
i have not configured this system with netinstall, but have used the 951G out of the box (i have a number of them, and so i know this is not specific to the specific router. Are there any additional requirements that need to be configured to allow this feature to work?
I have a RouterBoard 1100 which was recently upgraded from 5.25 to 6.2. Since then the computers from various internal subnets can’t see each other. I’ve attached the config file. Any help would be appreciated.
this happened since I have the v6.x. probe and with all
I am writing to you in order to let them get that error. few days ago, I’m having problems in my ccr1036, with version 6.2. This problem causes all BGP connections frequently disconnect, making it impossible to operate in this way. I need a solution urgently. no more.
I need an answer, it is urgent. attachment autosupout.rif
I think I found a bug in version 6.2
I added a NAT rule in the dst-nat chain to port forward to an internal device.
When I did that I immediately got disconnected via Winbox (winbox crashed).
Lucky for me I still could get connection via ssh.
By connecting to ssh I found out that the order of the firewall filter has changed.
The rule allowing me to access the device by winbox was set below the implicit drop rule I have.
Is this a known issue or something to do with winbox.
I’m using winbox on Windows 7 ultimate x64
Hy guys, i’m a new guy here
and i need your help because i meet a problem how i can create user-manager in mikrotik version 5.4
if i use mikrotik version 4.17
i use this command and working
/tool/user-manager/user/add=subscriber=subscriber=name= user_m=password=pass_m=uptime-limit=1d=add-credit=1d
but if i user in mikrotik version 5.4 is not working
/tool/user-manager/user/add=customer=mikrotik1=username=test1=password=t1=copy-from=user1d
i already create the profile but still not working
You should post it in one (!) thread where it belongs or - if there is no suitable existing thread - open a new one in a suitable sub-forum. Your post has nothing to do with Mikrotik news or RouterOS 6.2
For those using 6.3RC1, new release out 28/8/2013 12:32:24
change since the 22/08:
*) console - added ‘/console clear-history’ command that clears command-line
history for all users, requires ‘policy’ policy;
*) sstp - limit packet queue for each device;
*) RB2011L - fixed occasional gigabit switch-chip lockup;
*) user manager - will warn on 1MB and stop before reaching minimum of 500KB disk space;
