I’ll try it the next time.
Thanks.
Thanks.
Yes - ETH2, ETH3 and Wireless are under one bridge. ETH1 which leads to isp is not bridged.
If I understand well, I should set the admin-mac - but for what value? should I make a random mac and put it there?? Does it also mean to set “auto-mac” to no?
Easiest way is to use actual mac-address of bridge as admin-mac. Admin-mac SHOULD BE, and present mac-addres IS, one of hardware MAC of bridge members. So present mac-address is HW MAC of ETH2 or ETH3 or WLAN1. Just copy it to admin-mac. After you set admin-mac, auto-mac will be “no” automatically.
But be careful, if you set admin-mac for ex. as MAC of ETH3 and in future will be ETH3 removed from bridge, you must also change admin-mac of bridge to ETH2, etc.
I have upgraded RB750G from 5.x to 6.2.
While in 5.x the following worked OK:
:if ([:typeof $ddnslastip] = nil) do=
in 6.2 the condition is never true. It only works using “nil” instead of nil:
:if ([:typeof $ddnslastip] = “nil”) do=
Many scripts stop working because of this. In another thread someone wrote:
“FYI in 6.2 it is “nil” since it is a global, but it is “nothing” <= 6.1 and >= 6.3.”
Does this mean that .typeof behaves different in almost any 6.x version?
Allready 6.3 released. Very nice DHCP settings
I upgraded my RB750G to 6.2 and everything is working fine (30 days since the upgrade).
The only thing that is strange is that in the System > Resources under Sector Writes Since Reboot it states only 930 and rising. Then I logout and connect in 3 days time, the number is just a little higher: 970. If I stay on this page for a minute, the number increases way faster. It’s 1004 now. So If I look at it, the number rises, but if I don’t look at it, it rises too slow.
Is this a bug or a feature (Schrödinger’s cat feature)?
6.3 is released? As in the final version?
Sent from my SCH-I545 using Tapatalk 4
BUG REPORT
Platerform: 1100AHx2
Router OS: 6.3 30/09
Ethernet link in 10Mbits is not possible in Full Duplex. fixed manually without autoneg. both side for sure.
Working OK in 5.25 & 6.2
Renew changelog, please… On release page it stopped at 6.2 version.
