RB912UAG-5GPnD, same behavior after update, cannot access administration using any method.
Please put that version down from mirrors, contains bug
Mine was 6.29.1 from factory.
6.31rc10 and 6.32rc6
We have removed the v6.32 download for now (some might still see it due to cache) until we investigate
Are you all using wireless-fp or wireless-cm2 on those Baseboxes?
As said already yesterday..
Board: 912UAG-2HPnD
Coming from Ros (netinstall): 6.30.4 or 6.31 (absolutely clean config)
Upgrading to 6.32rc6 or 6.32 (today released & now suspended) the 912UAG-2HPnD cannot be accessed winbox/telnet/mac_telnet/web
Impossibile to generate a supout ..in order to regain access I need to netinstall again.
Netinstalling directly to (bundle) 6.32 ..the board has the same problem.
bajodel - do you have a wireless card installed? if yes, which one? which wireless package do you use ?
..&.. also netinstalling only system package 6.32 to 912UAG-2HPnD leads to the same problem
P.S.(1) No added wireless card (mPCie) ..only the onboard one
P.S.(2) Normally I enable cm2 package ..but also netinstalling system_only_pck leads to the problem
Fine, so you acknowledge the fact that “current” means not ‘most stable’ (=unstable)? And still you guys give this version as the only option for auto update or newbee updates from the website. This is serious a policy mistake. No wonder why the competition grows ten fold compared to MT… you guys are selling inferior products to your user and pull new users off by the same…
One more time;
auto update scripts look for “current” version, as will do any non experience MT user.
If MT put a “current” version on a website 99% of the people will consider this to be a stable version.
100% of automated scripts will see this version and start auto upgrading.
This is the worst policy I have seen in years…
We ‘die hards’ already know we are beta testers… newbees will quickly find out they are too…
New posts already showing I am right, only 4 hours after the initiation… pfffff
all basebox2 with R11e-5HnD cm2 package
Do you have another MikroTik router on the same LAN as the one you cannot reach? If you do, you could try /tool mac-telnet
By the way, dragging and dropping multiple items (e.g. firewall, NAT, and mangle rules) in Winbox is broken since probably 6.30.
You can select multiple items, but when you drag and drop, only the item you clicked to drag gets moved.
493G upgraded via web interface System / Packages from 6.31 to 6.32 went to reboot loop and had to be recovered via netinstall. Now running 6.30.4 and works again.
No issues on:
1 x CCR1016-12G
5 x RB951G
2 x CRS125-24G-RM
1 x RB751G
1 x RB532A
1 x RB951U
1 x RB751U
But my question is the 6.32 that everyone’s downloaded before it was removed, will this then remain 6.32 or become 6.32.1 but current not bugfix… ![]()
I have a PowerBox (RB750Pr2) experiencing this issue right now, upgraded from 6.32rc5. Two others have been upgraded without issue - one came from 6.32rc5, one came from 6.31. All three units are being used as 10/100 PoE switches, no routing/ACL/FW functionality used. Only DHCP, system, and security packages enabled. RouterBoot was current (3.24 IIRC).
MAC telnet does not work, presented with a login/password prompt, and the session was immediately closed. Does not respond to IP ping, does respond to MAC ping.
I have not power cycled this unit yet, and probably will not do so until I am in a position to replace the unit if it cannot be recovered remotely.
After upgrade to 6.32 /interface wireless print output is empty,wifi dont work.
X86 with dlink DWA-520
Wireless (Atheros AR5213)
/system resource pci print
Atheros AR5001X+ Wireless Network Adapter (rev: 1)
and
lcd - fixed parallel port LCD display support on multi-cpu x86;
6.32.rc6 work! 6.32 dont work… o_0
This is happening to me on my 493G. However, netinstall is not able to recover - it’s never seen in the Routers window. My RB450G shows up just fine, so I know it’s not a ‘turn off your firewall’ fix.
Troubleshooting, I can stop the boot with serial and boot from Ethernet. Running netinstall, I see the 493G get an IP through bootp, then a kernel from tftp. But that’s it…
I see with the 450G the next step is that the board will broadcast UDP to port 5000, and I suspect this is what populates the ‘Routers’ section. The 493G does not send these broadcast packets, so is there a problem with the kernel it gets via tftp? Can I manipulate this kernel?
Upgraded from 6.31. If there is a lot of ipsec traffic, there is a kernel failure and the device reboots. Downgrade to 6.30.4 didn’t help.
A lot of traffic = 2x CCR1009-8G-1S-1S+ connected with 1Gbps, IPsec with AES256 / SHA512 + iperf over a time more than 10sec
sep/01/2015 20:01:22 system,error,critical System rebooted because of kernel failure
sep/01/2015 20:01:22 system,error,critical router was rebooted without proper shutdown, probably kernel failure
*) firewall - fixed limit and dst-limit options.
requesting more details on this =)
I’ve open a ticket with support on this problem:
http://forum.mikrotik.com/t/drop-telnet-failure-login/90686/1
also another user has same
http://forum.mikrotik.com/t/dst-limit-filter-rule-problem/90803/1
Support say me that will fix in next release (6.32)
After upgrading from 6.30.4 to 6.32 all mangle rules have disappeared. Yes, I am looser and no backup exist.
I hate you, MikroTik.
