L2TP / IPsec VPN from Android is not working since I upgraded to 6.34 Reverted back to 6.33.5 and it works again. Mikrotik to Mikrotik works providing they are all 6.34 But log doesnt even give errors on 6.34 with Android VPN connection attempts.
I have got just the same issue. IPSEC between Mikrotiks only work if they all have 6.34 version. Android cannot connect via L2TP+IPSEC after RouterOS upgrade.
*) ipsec - fix phase2 hmac-sha-256-128 truncation len from 96 to 128
This will break compatibility with all previous versions and any other
currently compatible software using sha256 hmac for phase2;
We also are seeing traffic graph issues with the release. rc41 was fine. After upgrade to the release the graph shows lower values than the interfaces do.The only lines in the graph that look to be proper size are ones that were drawn while refreshing the graph page.
So the first two graph lines at 9am local time show traffic to be around 1Gbps which is correct. After leaving and coming back 10 minutes later I refresh and the very next line shows less than 200Mbps.
We also opened ticket [Ticket#2016013166000402] as we have exactly the same thing, SNMP is reporting about 1/10 of real actual traffic passing through.
timoid, Red0ktober - We have tested upgrade on these devices and it works. It must be configuration related. Please contact support.
Those who complain about missing “Switch” menu in Winbox - upgrade Winbox to 3.1 and you will see this menu. Everyone - please report to support@mikrotik.com with description of your problem and screen shots. Forum is for users. If you want to have resolution to your issues, then you should report to support.
well, congratulations for the Dude project - working fine…
But, also some problems here with 6.34-update :
Main-Router 2011UiAS-2HnD and two RB952Ui-5ac2nD with CAPsMAN-configuration.
I recognize that two mobile phones are drained when connected to AP/CAPsMAN.
Is there something wrong with Powermanagement (edited: not WMM) or similar function ?
After 8-10 h both batteries are drained until 5% remaining, before update running time was about
5 days… (both values with similar using situations).
Installed is wireless-cm2 on all devices..
If you need more specific informations about my configuration, please feel free to contact me.
There is something wrong in 6.33.6 and 6.34 relating secondary column sorting in WinBox, both 3.0 and 3.1. See the screenshot from 6.33.5 and previous versions - I use the sorting where ascending Address is primary and descending Expires secondary column.
I can not set that in newer RouterOS. (I have just tried my home RB2011UiAS, nothing else)
Well, because of many static entries in my dhcp-server-leases-list, I thought dynamic entriess are gone.
They are only sorted by ip-address, as my dhcp-pool is at the end of the ip-block (>x.x.x.230),
I can see them, but not at first position as before…
Perhaps a new feature ?
Then there is a lack of sorting by “dynamicly” entries.
What is the actual problem with sorting? We fixed Winbox and DHCP leases. Big part of information was not shown for static entries. Now you can see it. Please send to support@mikrotik.com screen shots where we could see correct and incorrect behaviour.
