Sorry guys but why do not you paying attention?
After several months and after a lot of rc release of new major version is full of basic errors. (GRAPH, SNMP, etc.)
It’s not very good…
The RouterOS software version 6.34 is the 34th major release of RouterOS 6.
What’s going on with you?
Probably graph counters show less traffic because the code that hides traffic generated by the new backdoor includes also normal packets… (just kidding).
I noticed when upgrading a CCR1036 with V6.34. snmp with cacti shows incorrect data. The Cacti will flatline on a read of 80mbps or whichever for about an hour or so and then update correctly again. When you log into the unit the SNMP data updates correctly immediately.
We noticed as there were large gaps where the data was exactly the same on Cacti and when we logged into the unit, while there was this flatline, the router showed different values. A minute after logging in the Cacti data with synchronize correctly again.
RB951Ui-2HnD:
Can’t do web proxy to external disk. Tried USB Flashdisk and USB HDD External, same result. After building cache, running, can’t open anything. Few files entered USB disk but can’t clear cache.
If untick Cache to Disk, everything works normally.
