v6.35 [current] is released!
What’s new in 6.35 (2016-Apr-14 12:55):
Known issue: some huawei lte modems might not get IP address after the reboot of the router - disable/enable of the modems fixes that
*) arp - apply Linux Kernel patch to stop RouterOS from randomly exhibiting misplaced ARPs;
*) mipsbe - (excluding RB4xx and CRS series) fixed rare ethernet tx buffer corruption;
*) nand - implemented once a week nand refresh to improve stored data integrity (will increase sector writes);
*) pppoe-client - implemented fastpath support;
*) l2tp - implemented l2tp and lns fastpath/fasttrack support;
*) queue - added bucket-size setting to queues (derived from max-limit);
*) tile - fixed rare situation when some cores decide not to take part in packet processing till next reboot;
*) tunnels - fixed performance slowdown on any other tunnel disable/enable;
*) winbox - increased minimal required winbox version to 3.4;
*) wireless - added new package “wireless-rep”;
*) wireless - improved 1-chain 802.11ac station compatibility with other vendor multi-chain APs;
*) address-list - fixed crash in low memory situations;
*) bonding - fixed crash when creating vlans on bonding interface;
*) capsman - added 802.11g/n band;
*) capsman - fixed capsman extension channel names;
*) certificate - revoked certificates not showing as (R)evoked;
*) certificate - allow manual crl url addition;
*) chr - added support for VLAN on Hyper-V;
*) chr - fixed Hyper-V booting from SCSI;
*) chr - fixed Hyper-V on windows 8/10 reboot loop;
*) chr - fixed bridge firewall;
*) chr - fixed kernel crash when virtual ethernet was not connected to anything in Hyper-V;
*) chr - implemented automatic storage increase on disk image size increase;
*) chr - implemented kernel crash saving to autosupout.rif (will utilize additional 24Mb of RAM);
*) chr - make shutdown request from hyper-v work (might fix other hypervisor as well);
*) chr - no more installation on first boot;
*) chr - try to renew expired license once a hour instead of 100h;
*) cloud - don’t write minor status changes to storage;
*) console - fixed print follow in “/ip dns cache” menu;
*) console - show RouterOS Version in /interface wireless scan;
*) console - sort completions/hints in natural order;
*) console - update copyright notice;
*) defconf - fixed default configuration for SXT LTE;
*) dhcpv6-client - fixed wrong error message;
*) dhcpv6-client - fix ia expiration and lifetime validation;
*) dhcpv6-server - acquire binding on renew if it does not exist;
*) dude - (changes discussed here: http://forum.mikrotik.com/t/the-dude-work-continues-v6-35rc-test-builds/94981/1);
*) dude - fixed dude login logging, no more shows as winbox login;
*) email - fixed send cmd server addr override;
*) ethernet - add option to see S-GPON-ONU module, GPON side SN in “/int eth mon sfp#”;
*) ethernet - do not allow to set self as master port;
*) export - bonding did not show up in global export;
*) export - exclude default values from export in “/interface l2tp-server server” menu;
*) export - fixed export when ipv6 address was taken from pool;
*) export - fixed rare situations when not whole config was exported;
*) export - updated defaults for compact export;
*) fastpath - fixed crash when packet arrives on disabled interface;
*) fastpath - fixed show rx-bits-per-second on all VLAN interfaces;
*) fastpath - improved vlan fastpath;
*) fasttrack - fixed timer updating in connections table for fasttrack connections;
*) fetch - decrease connection idle timeout;
*) firewall - added experimental “action=route” in mangle prerouting - that forces packets to specific gateway by ignoring routing decisions (CLI only);
*) health - always report fan speed (even if it is 0);
*) health - swap fan2 and fan3 on CCR1072;
*) hotspot - clean-up all dead entries at once;
*) hotspot - fixed possible deadlock;
*) hotspot - improved html page resistance against attacks;
*) hotspot - make video tag work properly on hotspot login.html page
*) ip - rename max-arp-entries to less confusing max-neighbor-entries;
*) ippool6 - fixed potential crash;
*) ipsec - always re-key ph1 because it was possible that ph1 without DPD would expire;
*) ipsec - better flush on proposal change;
*) ipsec - fixed crash on policy update;
*) ipsec - fixed fast ph2 SA addition;
*) ipsec - fixed larval SA refresh for display;
*) ipsec - fixed multiple consecutive dynamic policy flush;
*) l2tp & pppoe - fixed user traffic accounting when fastpath was used;
*) l2tp - introduced per tunnel allow-fast-path option;
*) l2tp - added support for Hidden AVP, it is needed for proxy authentication;
*) l2tp - added support for max-sessions;
*) l2tp - added support for proxy authentication when receiving forwarded PPPoE sessions;
*) l2tp - fixed small memory leak on reconnects;
*) lcd - fixed branding packet logo drawing on startup;
*) led - fixed crash on assigned interface removal;
*) led - turn on fault led on CCR1072 if CPU too hot;
*) leds - fixed AP-CAP led blinking after successful association to CAPsMAN;
*) lte - added ipv6 support for SXT LTE;
*) lte - changed AT command processing;
*) lte - changed AT parsing because supported Huawei modems use unsolicited events instead of polling;
*) lte - fixed bandlux modem dialing;
*) lte - fixed crash on early initialization;
*) lte - improve situation when SXT modem never finds operator;
*) lte - replaced signal-strength with rssi in info command;
*) lte - support Alt38XX modem;
*) lte - support for zte mf820s2;
*) lte - supported modems now use unsolicited events for network monitoring;
*) lte - use timer for modem info;
*) map lite - added hardware WPS button support;
*) mpls - do not reset VPLS on TE tunnel re-optimize;
*) ntp - fixed ntp client hangs in reached state;
*) ospf - fixed crash when getting neighbor router-id in NBMA area;
*) ppp - fixed ppp interface reconnect when uPnP was used;
*) ppp - close connection if peer wants to re-authenticate;
*) ppp - fixed memory leak high number of pppoe clients to the same server;
*) ppp - fixed ppp crash if lcp packets were lost and authentication got delayed;
*) ppp - fixed some clients can not connect due to LCP restart;
*) pppoe - added rfc4679 support;
*) pppoe - fixed crash when removing pppoe service;
*) pppoe-server - added pado-delay option;
*) profiler - classify certificate signing;
*) proxy - fixed ftp request url decode;
*) queue - improve “/queue interface” menu;
*) quickset - fixed invalid date adjusted the signal threshold for the signal chart and refresh rate;
*) quickset - fixed situations when hidden password was passed as ******* from winbox nd webfig;
*) radius - warn radius client if incorrect secret is being used;
*) rb3011 - fixed sfp compatibility with CCR when using direct attached cables;
*) rb3011 - fixed time keeping;
*) rb3011 - make ether6-ether10 work if SFP module is present on bootup;
*) romon-ssh - fixed active addresses for romon user;
*) route - do not show duplicate gateway on connected route;
*) route - fixed filter by routing table;
*) routing - fixed rare kernel failure on different dynamic routing configurations;
*) routing - fixed routing-marks were not erased from memory when they are not being used;
*) services - do not show ssh entry under ip services if security package is disabled;
*) snmp - don’t group oids for bulk get with maxreps > 1 ;
*) snmp - fixed cpu load reporting to 1min average and change oid to 1.3.6.1.4.1.2021.11.10.0;
*) snmp - fixed dhcpv4 lease hwaddr format according to mib;
*) snmp - fixed getbulk result ordering with multiple request OIDs;
*) ssh - simplify login process;
*) ssl - optimized certificate update;
*) system - log time changes;
*) tile - corrected max-l2mtu;
*) tile - fixed fastpath related memory leak;
*) tile - fixed performance regression on switch chip (introduced in 6.33rc18);
*) tile-crypto - fixed minor memory leak;
*) tool fetch - fixed https cleanup on user stop while handshaking;
*) trafficgen - fixed console arguments;
*) trafficgen - fixed crash when unexpected stream reappears;
*) trafflow - fixed potential deadlock;
*) ups - fixed entering hibernate mode when below battery capacity limit;
*) users - added separate RoMoN policy;
*) webfig - fixed firewall rule sorting did not work in other chains except all;
*) webfig - show single item groups as optional values;
*) webfig - sort numeric columns numerically even if they contain some text;
*) winbox - added “pw-type” to “/interface vpls bgp-vpls” menu;
*) winbox - added “use-control-word” and “pw-mtu” to “/interface vpls cisco-bgp-vpls” menu;
*) winbox - added /interface wireless setup-repeater;
*) winbox - added all the rates settings to the capsman;
*) winbox - added flip-screen option to lcd settings;
*) winbox - added init-delay option to routerboard settings;
*) winbox - added ipv6 firewall missing log option;
*) winbox - added missing eap-ttls-mschamv2 method to wireless security profile;
*) winbox - added mtu=auto support to eoipv6 tunnel;
*) winbox - added sfp-mac for GPON interfaces;
*) winbox - added support for new settings from wireless-rep package;
*) winbox - added support for route action in mangle rules;
*) winbox - allow to set additional-network-modes;
*) winbox - allow to set multiple dh-groups;
*) winbox - disable autostart for wireless scan,snooper,align etc. on open;
*) winbox - do not show “enable-jumper-reset” setting on devices without serial port;
*) winbox - do not show real-tx-power column in current-tx-power by default;
*) winbox - fixed unset options in /routing ospf interface menu;
*) winbox - hotspot default-trial user shows profile as “unknown” in Winbox;
*) winbox - improved winbox connection loss detection, fixes winbox safe mode;
*) winbox - limit ospf key to 16 symbols;
*) winbox - make additional-network-mode optional for lte interface;
*) winbox - make build with latest lte changes;
*) winbox - make mrru disabled and set mtu+mru to auto by default on new servers;
*) winbox - show “usb-power-reset” option on all boards that have it;
*) wireless - fixed crash on nstreme-dual interface stats update;
*) wireless-rep - added 802.11g/n only band;
*) wireless-rep - added STEP feature for the scan-list;
*) wireless-rep - added WPS client support;
*) wireless-rep - added support for saving wireless scan results to file;
*) wireless-rep - added support for wireless background scan for 802.11 protocol;
*) wireless-rep - added support for wireless repeater mode for 802.11 protocol;
*) wireless-rep - added support for wireless scan rounds setting;
*) wireless-rep - adjust roaming scan times;
*) wireless-rep - allow to connect to AP after scan;
*) wireless-rep - do not allow empty ssid for AP modes;
*) wireless-rep - fixed crash on non-HT clients;
*) wireless-rep - fixed latency issues with Intel wireless clients;
*) wireless-rep - fixed nv2 protocol;
*) wireless-rep - fixed qos frame-priority when nv2 protocol used in station-wds mode;
*) wireless-rep - fixed signal leds;
*) wireless-rep - fixed speed issue when connected with Intel 802.11ac;
*) wireless-rep - initial support for station roaming for station mode in 802.11 protocol;
*) wireless-rep - request interface name for setup-repeater;
*) wireless-rep - use full identity where possible;
*) wireless-rep,capsman - added more configuration settings;
*) wireless-rep,capsman - added rate config support.
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
OMG .. 2 meters long changelog :slight_smile: :slight_smile:
A note for users who want to upgrade to v6.35 from 6.35rcXX:
We have found the issue randomly causing boards to fail on upgrade during the rc testing, this fix is included in 6.35 (current),
To successfully upgrade to 6.35 from 6.35rc29-rc49, please do a /system reboot, and then on bootup make an upgrade straight away.
what exactly those ones are doing?
iisues. .upgraded made me upgrade winbox.. now when I try to log in with winbox it wont let me says rmon is not enabled.
Yes. It is very nice. All changes desribed and sorted!. Not like before… :slight_smile:
Very nice work Mikrotik :wink:
Can we get changelog since last rc?
CCR1016-12G just came unresponsive after upgrade from 6.34.3 to 6.35
Upon reboot I see the ethers all come up on kernel boot, as soon as starting services they all go away.
Reset config I get ethers back but load my backup all goes away again.
Can’t send supout as I can’t talk to the CCR only factory default works. Had this since 6.23 and it’s never happened ever.
Just tried going back to 6.34.4 and load backup no issue.
Suggestions?
Is this not the only way to do an upgrade? You upload the new package anyway you want (ftp, drag and drop winbox, telnet) and only after the reboot the new packages are installed? Or am I wrong here?
I had 6.35rc43. So I do a reboot via WinBox, wait till WinBox reconnect, make an upgrade via System > Packages > Download&Install. But I got beeping & cyclically rebooting brick instead of router.
What I do wrong? Should I reboot via terminal instead of WinBox? Or making upgrade via “System > Packages > Download&Install” isn’t “straigh way”?
Thank you for thorough testing, Mikrotik team!
UPD: well, I have successfully recovered my router via NetInstall, but the situation itself is very unpleasant.
Found out why my CCR1016-12G became dead on all ethernets!
Okay why was the maximum L2 MTU dropped by 4 bytes?
Used to support 10226 now dropped to 10222
Thanks for the warning :frowning:
Wasted 20 minutes reloading configuration… down and up versions, etc, etc :frowning:
I don’t see this. Upgraded a 951Ui and added wireless-rep (it was not included in main package)
it is in thechangelog:
where do you actually use such L2MTU? i had 9100 and no problems on upgrade.
:slight_smile: you really need to choose one of two: ether complain about netinstall OR using RC versions. Both don’t go together.
CCR to CCR
CCR1016 series ether1-ether12:10226; sfp1-sfp12:10226; sfp-sfpplus1:10226
CCR1036 series ether1-ether12:10226; sfp1-sfp4:10226; sfp-sfpplus1-sfp-sfpplus2:10226
CCR1072 series ether1:9116; sfp-sfpplus1-sfp-sfpplus8:10226
On CRS125-24G-1S I have these new lines appear in my configuration export:
set 0 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 1 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 25 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
What’s the deal about these? Documentation in wiki says this is the default value anyway…
http://wiki.mikrotik.com/wiki/Manual:CRS_features#Port_Settings
I have a PPPOE over VPLS network.
VPLS from Base Box 5 (Client access point) to CCR1036 (PPPOE concentrator)
Upgrade Base Box 5 from 6.34.2 to 6.35 broke my VPLS. Cannot ping at 1508 without fragmentation. Revert back to 6.34.2 and everything is OK.
keep up the good work guys :smiley:
Massive update!
Its also been one of the longest number of release candidates I think I’ve ever seen(me since v4.17). Thought I was going to see an RC50 in there :slight_smile:
Just upgraded a RB-951-2n to 6.35, so far so good for that unit..
Upgraded RB2011UAS-2HnD from 6.34.2 to 6.35 and router boot to 3.33 via npk file. Looking good so far.
Can’t wait to test pppoe-client fastpath support. ISP here just rolled out 100, 300 & 500mbps FTTH.
