Version 6.36.4 has been released in bugfix channel.
What’s new in 6.36.4 (2016-Oct-05 11:24):
!) ssl - fixed peer address/dns verification from certificate (affects sstp, fetch, capsman);
*) console - hotspot setup show wrong certificate name;
*) ethernet - added support for LAN9514 ethernet dongle;
*) ethernet - allow to force mtu value when actual-mtu is already the same;
*) firewall - fixed dynamic dummy firewall rules appearance in raw tables;
*) firewall - fixed time based rules on time/timezone changes (again);
*) hotspot - fixed nat rule dst-port by making it visible again;
*) ipsec - changed logging topic from error to debug for ph2 transform mismatch messages;
*) ipsec - fixed dynamic policy not deleted on disconnect for nat-t peers;
*) ipv6 - improved system responsiveness when ipv6 routes are frequently modified;
*) led - fixed default led settings for wAP2nDr2;
*) lte - added dlink dwm-157 D, dwm-222, Pantech UML295, Vodafone K4201-Z, ZTE MF823/MF831 support;
*) lte - added rndis for ZTE MF8xx;
*) lte - added zte K5008-Z back;
*) lte - fixed setting correct lte band for sxt lte;
*) mpls - fixed memory leak;
*) pppoe - fixed disconnects by idle timeout when fastpath is used;
*) rb3011 - fixed rare occasions when router would hang while loading kernel;
*) sstp - allow to specify proxy by dns name;
*) tile - do not reboot device after watchdog disable/enable;
*) traffic-flow - fixed dst-port reporting if connection is not maintained by connection tracking;
*) userman - always re-fetch table data when switching between different menus;
*) userman - fixed memory leak on user limitation calculations;
*) userman - fixed timezone adjustment in reports;
*) webfig - fixed certificate signing;
*) webfig - fixed channel selection in check-for-update menu in Firefox;
*) winbox - added auto refresh for BFD neighbors;
*) winbox - adjust on-event field dynamically depending on window size;
*) winbox - adjusted allowed values for http-proxy field;
*) winbox - allow to unset http-proxy field for sstp client;
*) winbox - fixed typo in dhcpv6 relay (DCHP to DHCP);
*) winbox - removed health menu from devices that do not support it;
*) winbox - removed unset button for L2MTU field;
*) wireless - show DFS flag in country-info command output;
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
Hi, i have rb951g and nexus 5x phone.
with ros 6.34.4 bug fix version wifi works fine, but with newer version phone wifi keep phone active.
With ros 6.34.4 wifi last activity on phone when idle reach 20sec, on newer version when phone idle wifi last activity max 0.2sec.
Hi everybody,
yesterday I upgraded couple of mipsbe devices (IPv4/v6, VPN - SSTP, L2TP/IPsec, OpenVPN, GRE6/IPsec tunnels, PPPoE, OSPFv2/v3, wlan 2Ghz/5GHz, etc.). I did not encounter any problems so far (neither during upgrade nor during function). Thanks to developer!
Can someone tell me if there are something to disable before upgrade this bugfix ?
I had saw (but I don’t know where) that wireless package will be changed or something like that.
Found some issues.
After one day, I found a lot of Hex and Hex-lite , RB750GL with cpu 100% on unclassified.
did reset to factory
re-applied configuration from export, and after a few minutes again 100%.
downgraded to 6.34.6 and the router is perfectly fine
the same router with the same conf that worked for years on 6.37.1 works flawlessy.
Maggiore81 - Please try to generate supout file on your device and send it to support. Also check Log - your device might be under attack.
Tornike - Most likely you have device with “/flash” directory. Is that correct? http://wiki.mikrotik.com/wiki/Manual:System/File
"Warning: If device has a directory named “flash” in its file list, then files which you want to be kept after system reboot/power cycle must be stored within it. As anything outside of it is kept within a RAM disk and will be lost upon reboot. Note: this does not include .npk upgrade files as they will be applied by upgrade process before system discards the RAM drive content. "
kos - Please try to generate supout file on your device and send it to support.
Well I did the upgrade router booted up fine but I have no wifi, it was disabled after upgrade. Even after I activated the wifi package it did not want to reenable wifi. Had to reset and reinstall it all with netinstall to install v37 on it to fix the issues. Now my wife is telling me the router disconnects her from the wifi… I will have to look into that when I get home.
I was under the impression you changed wifi for version v37 and forward, not v36.
