v6.37 [current] is released!
after two days working on 6.37 without any load
on the previous versions I two years have not seen such a.
Is wrong on winbox (probably) on on terminal?
Affect ALL routeros version where wireless/channel are present, not only 6.37 or 6.36.3
EDIT - Update - Good News
Working with a problem Mikrotik that every time lost the wireless interface when upgrading from 6.36 to 6.37 which resulted in two different versions of the wireless package (one was new at 6.37 and the old was 6.20 (where ever the 6.20 came from I have noo idea). Both wireless packages were disabled and the only recovery was to downgrade to 6.36 then restore the last backup configuration.
What worked was upgrading from 6.36 to 6.38rc7
The wireless link came back
However - there was still the older disabled wireless 6.20 package
I did another reboot - when it came back then everything looked good - there was no longer a second older wireless package.
North Idaho Tom Jones
Dynamic queue from hotspot get wrong priority
I tried to set priority 6,7,8, not specified then update user profile, reset hotspot server but priority of dynamic queue still 1
I had the same problem
I had the same problem, unable to remove any old wireless package left in 6.37. I had to downgrade the router, remove the wireless package, then reupdate.
again, after 24 hours
will have to roll back to 34
after upgrade to 6.37 (from 6.36.something) my RB493G is not reachable. Neither winbox or netinstall is able to see it. I tried to make a reset by short-circuiting the on board reset “button” while attaching the power adapter but that doesn’t seem to be working either (the beeps seems to be the same as normal install). I don’t have serial cable to attach to RS232 to try.
Any ideas what might went wrong or what else I could try to re-live my RB again?
Thank you for any help.
Herbert
I also have a lot of wireless issues with 6.37. MacBook and printer HP working worse. Wireless-cm2 was stable. How to downgrade to 6.36? Thanks.
upd: did it.
[quote=“strods”]We just released 6.38rc. Please test if wireless package issues are gone:
http://forum.mikrotik.com/t/v6-38rc-release-candidate-is-released/102037/2]
I upgraded to 6.38rc and have wireless operational again but in packages is V6.19 wireless ??
Something is very wrong with both V6.37 and V6.38 ??
If you see multiple wireless packages after upgrade on your device then the spare one will disappear after next reboot.
Did you plan to restore cm2 packet? 6.37 very unstable with Apple devices
Please tell us more detailed in what kind of setup the Apple devices are unstable?
With 6.37 It needs more time to connect. When I open the lid of macbook I should wait about 1min. With 6.36 it is much faster. Also my printer by HP, when I connect it to 220V, it power on and shows on display that it connect to WiFi, but ip-address like 169.254…xx (I do not remember exact digits). And after 2-3min it gets normal ip-address. With 6.36 it also much faster. About 10-15 sec.
What setup you have on the AP? 2.4ghz or 5ghz? Encryption or not?
Maybe you could send the support output file of the config to support@mikrotik.com so we could try to reproduce this problem?
Printer use 2.4Ghz, MacBook - 5Ghz. Encryption AES. Sure I can. Wait a moment.
upd: check your mailbox.
Version 6.37.1 has been released:
http://forum.mikrotik.com/t/v6-37-1-current-is-released/102133/1
