v6.40.5 [current]
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
What’s new in 6.40.5 (2017-Oct-31 13:05):
*) certificate - fixed import of certificates with empty SKID;
*) crs3xx - fixed 100% CPU usage after interface related changes;
*) firewall - do not NAT address to 0.0.0.0 after reboot if to-address is used but not specified;
*) ike1 - fixed crash after downgrade if DH groups 19,20,21 were used for phase1;
*) ike1 - fixed RSA authentication for Windows clients behind NAT;
*) ipsec - fixed lost value for “remote-certificate” parameter after disable/enable;
*) ipv6 - fixed IPv6 addresses constructed from prefix and static address entry;
*) log - properly recognize MikroTik specific RADIUS attributes;
*) lte - do not reset modem when it is not possible to access SMS storage;
*) lte - fixed modem initialization after reboot;
*) lte - fixed PIN option after setting up the band;
*) sms - include time stamps in SMS delivery reports;
*) sms - properly initialize SMS storage;
*) snmp - fixed “/system license” parameters for CHR;
*) winbox - allow shorten bytes to k,M,G in Hotspot user limits;
*) wireless - fixed rate selection process when “rate-set=configured” and NV2 protocol is used;
tool sms inbox message error
all message recib error
CCR1009-8G-1S-1S+
May/11/2001 07:15:07 GMT +11 a ekKECAdKGSESIC$o @@@@@@
SL@@@@@@d$@@@@@@@Xe@@@@@@@@*CUw@@@@@Ru=o$@@@@oae@@@@@@L;D@@@@@@0:haA
The rb2011uias2hnd can not boot after upgrade from 6.40.4 to 6.40.5 !!!
Sent from my C6833 using Tapatalk
just updated from 6.40.4 to 6.40.5 and i hear a loop reboot with a periodic beep sound!
HELP! What should i do to recover my router?!
Please connect serial cable to your router, open serial console and power on the router. Send whole serial output to support@mikrotik.com. Most likely problem is not related to specific RouterOS version and is caused by some kind of issue during upgrade process.
Also you can try to power off router, press and hold reset button. power router on and release the button. If router now boots up, then run command “/system routerboard upgrade” and then router should boot up normally after upcoming reboots.
“Also you can try to power off router, press and hold reset button. power router on and release the button.”
tried, no luck
I do not have any serial cable. What should i do? (hAP AC was bought a week ago)
Tried patch cord + netinstall… The device reboots and invisible in Netinstall app
When (version) did this go wrong and what was exactly the issue?
Whoa! I think I will pass on upgrading to this version…
I haven’t experienced firmware\BIOS update failure in ages. How this version passed QA tests? :frowning:
Installed RouterOS version does not in any way affect Netinstall process. Ether boot happens before you have reached RouterOS. If you can not Netinstall device then problem is either with Netinstall (recommended to test with another router), RouterBOOT or hardware.
Wireless fix is made for configurations where nv2 and configured rates are used. If you experienced system lock-up or reboots, then this fix will most likely will solve the problem.
it happened right after upgrade to 6.40.5
no other changes were done. What could have happened?!
cAP Lite died after upgrade
I have Tried Netinstall but router does not shown in List also I have pushed reset-button for more than 300sec
CAP-LED and WLAN-LED are just Blinking
There is no problem with Netinstall (tested)
Upgraded various Routerboards (RB433AH, SEXTANT-G, cAP-Lite, mAP-Lite, hAP-Lite, SXT, Groove, RB3011, RB2011, RB1200, RB850Gx2, x86).
No problems so far :slight_smile:
Updated through Winbox, pressed “Download and install”. Previous version was 6.40.4. Connection was over cable. Maybe it depends on this?
What was already done:
  1. Tried reset to default config - NO RESULT
  2. Tried NetInstall 6.40.5/6.40.4/6.38 - NO RESULT (device is not visible)
  3. Tried changing from 100Mbps to 1Gbps speed (thought it may be the reason. Based on RouterBOOT changelog: https://wiki.mikrotik.com/wiki/RouterBOOT_changelog) - NO RESULT (device is not visible)
  4. Tried holding reset for more then 300 sec (based on this manual: https://wiki.mikrotik.com/wiki/Manual:RouterBOARD_settings#Protected_bootloader) - NO RESULT. Router reboots even before 300 sec are passed.
Just found those devices in my collection. Would it be enough to get any useful information about the reasons of such disaster? I am interested to solve this problem as fast as i can (if i can :slight_smile:). - NO RESULT (device is not visible)
Is there anybody who will guide me through the process?
No problems on 3x cap 2n, 2x 951g-2hnd, 1x map lite and 1x ccr 1009. All from 6.40.4 to 6.40.5, with 3.41 RouterBOOT.
Hello, c400!
May you try to follow steps from this video https://www.youtube.com/watch?v=GIijZ6_i55g in order to Netinstall your device?
Thank you!
Done Netinstall based on your video manual. No luck. Device is not shown in the app.
Brand new hAP AC (Bought 28.10.17) became a brick. I am sure it is something with firmware ore bad circumstances
If you are not able to Netinstall the device, then maybe you have protected bootloader enabled?
I’ve upgraded RouterOS successfully on hAP lite, hEX and hAP ac from 6.40.4 to 6.40.5.
All devices had RouterBOARD firmware 3.41 before the upgrade.
So far so good…
Me too
same problem in cAP lite
If it is disabled by default, then i have not enabled it.
Any other suggestions? I do need help!
