v6.40.5 [current]
Hi.
I have a a few MK RB1100 on producction running the hotspot service and after update from 6.36 to 6.40.5 experience issues.
After x time 10/20/30 min, i suppose it depends on the amount of traffic, the portal starts to fail, could be:
Portal doesn´t appear or Login button does nothing, but firewall hotspot rules continues matching packets.
If i change any configuration on the hotspot server , everything start to work fine. Like if the service restarts resolve the issue.
My implementation use external radius server.
The ammount of simultaneous users is between 140 and 800
I have to say model CCR1016-12G woks fine with the same release.
Little “/export” issue:
in “ip dhcp-server” section, any setting to “bootp-support” (e.g. set bootp-support=none lan_dhcp) will not be exported
Version 6.41 has been released:
http://forum.mikrotik.com/t/v6-41-current/114978/1
