RouterOS version 6.43.1 has been released in public “stable” channel!
Before an upgrade:
Remember to make backup/export files before an upgrade and save them on another storage device;
Make sure the device will not lose power during upgrade process;
Device has enough free storage space for all RouterOS packages to be downloaded.
What’s new in 6.43.1 (2018-Sep-17 06:53):
Changes in this release:
*) crs317 - fixed packet forwarding on bonded interfaces without hardware offloading;
*) defconf - properly clear global variables when generating default configuration after RouterOS upgrade;
*) dhcpv6-client - log only failed pool additions;
*) hotspot - properly update dynamic “walled-garden” entries when changing “dst-host”;
*) ike2 - fixed rare authentication and encryption key mismatches after rekey with PFS enabled;
*) lte - fixed LTE interface not working properly after reboot on RBSXTLTE3-7;
*) rb3011 - added IPsec hardware acceleration support;
*) routerboard - fixed memory tester reporting false errors on IPQ4018 devices (“/system routerboard upgrade” required);
*) sniffer - made “connection”, “host”, “packet” and “protocol” sections read-only;
*) switch - fixed port mirroring on devices that do not support CPU Flow Control;
*) upnp - improved UPnP service stability when handling HTTP requests;
*) webfig - allow to change user name when creating a new system user (introduced in v6.43);
*) webfig - fixed time interval settings not applied properly under “IP/Kid Control/Kids” menu;
*) winbox - added “allow-dual-stack-queue” setting to “IP/DHCP Server/Leases” menu;
*) winbox - added “allow-dual-stack-queue” setting to “IPv6/DHCPv6 Server/Bindings” menu;
*) winbox - fixed corrupt user database after specifying allowed address range (introduced in v6.43);
*) winbox - make bridge port “untrusted” by default when creating new port;
*) winbox - show “IP/Cloud” menu on CHR;
*) winbox - show “System/RouterBOARD/Mode Button” on devices that have such feature;
*) wireless - removed “czech republic 5.8” regulatory domain information as it overlaps with “ETSI 5.7-5.8”;
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
Please keep this forum topic strictly related to this specific RouterOS release.
Where is bugreport page or bugtracker?
I am using IGMP proxy and VLAN on 3011, after updete form 6.42.7 to 6.43.0 or 6.43.1 IGMP proxy working with errors
If i using 6.43 firmware without VLAN IGMP Proxy working normally.
Just upgraded RB951G-2HnD v6.43 to v6.43.1. In both versions the multicast traffic doesn’t go, though the same configuration works fine in v6.40.9 and worked in previous versions for couple of years. Why so? I use multicast package, IGMP proxy and firewall rules to allow iptv traffic.
Still having issues with multipoint Wireless Wires. Connections take forever to stabilize after first boot. They reconnect constantly during this time which seems to have gotten longer with this release. Took 30 minutes for the links to stop flapping on 6.43.1
I am still seeing high memory use on my CRS125-24G-1s-2HnD, I did see before doing a routerboard update the use down to 33MiB but after its up to 54MiB much better than the 102MiB. I will have to watch the graph and see if it rises over time like I was seeing in 6.43.
Looking forward to just using this as a switch and moving to a RB4011 as soon as I can find a supplier selling it on Amazon, it would be nice if MicroTik would sell directly on some of the major sites.
