v6.44.6 [long-term] is released!
Nice stable release!
We have a few dozen hAp AC’s and SXT’s on this and 6.44.4
Have to keep an A/B setup as routeros refuses to install the same version packages over a bundle.
Was quite annoyed to receive a shipment of these as they will not install earlier versions.
Going to our internal stable is part of our provisioning, which broke with the new batch.
We assume it was due to now signing the packages. Good move but a little warning and/or a grace period would have been nice.
That said seems solid.
So a question, the one feature I’m really waiting for is SFTP support.
Any Idea when it will make it to long-term?
Went to stable in 6.45.1
Hello.
This morning (22.11.2019.) upgraded following RB:
hEX, RB750, RB450, RB2010UiAS, RB2011UAS, RB2011iL, RB1100, RB1100AHx2 and RB1100AHx4 - seems everything is working like a charm.
previousely used v6.37.1
Good job at “Long Term” version realice!
You will have to ensure your devices have not been compromised
hardware: HAP AC Lite
software: 6.44.6
firmware: 6.44.6
services: pptp server, sstp server, dhcp server, dns server, masquerade, dual wifi both on.
problem 1: when multiple (about 5) sstp clients connecting together at once, cpu load goes 100% then wifi rto for 15-20 seconds, then back to normal.
problem 2: after 28 days uptime, suddenly wifi getting so slow, all pptp/sstp clients cant connect, cant remote to winbox, need disconnect power then reconnect power.
All these problem not exist in 6.43.16.
addon 1: please add WinBox button in IP > Neighbors. Already have Ping/Mac Ping/Telnet/Mac Telnet/Torch. Why dont have Winbox? Already ask for this since long time ago.
addon 2: if we set: System > Routerboard > Settings > Auto Upgrade ON, then please do AUTO REBOOT TOO AFTER UPGRADE. Already ask for this TOO since long time ago.
Make it simple, man. Dont make it hard. We choose mikrotik not to get headache!
This is insane! I spent entire morning on a production network trying to figure out why after upgrade (to stable long term release!) my router does not respond to any DHCP DISCOVER requests. It shows them in log but not sending any offer. Later I found hundreds of “incomplete” arp entries in my core switch. Guess what? Conflict detection feature, that was enabled by default and sending ARP requests to L3 connected switch that relayed dhcp requests from remote segments. Nice Mikrotik. You introduced this “feature” in 6.44: http://forum.mikrotik.com/t/radius-server-not-working-in-2-8-11/127/1 and it still there. Really?
sba you are most likely using proxy arp on the relay router which will respond with its own MAC address to ARP requests causing false positive conflicts. Spending entire morning figuring out what is causing the issue when the issues is clearly mentioned in your Log sounds doubtful.
Nope. No proxy arp. Cisco switch with ip helper configured on vlan interfaces and L3 (/30 subnet) connection to Mikrotik. No bridges, just clean interface with address. Dhcp server have Relay address configured. So, in 6.43.14 worked for about a year without any issue. Update, reboot and surprise - all leases are in use with busy status and all zeroes in mac and ip.
So, what I supposed to clearly see in dhcp debug log? That it receives all dhcp packets, acknowledging renewals and completely ignoring discovers? Yes, that’s what I clearly saw. There was no word about failed arp requests. How that would link to “Conflict detection” ?
Scroll this thread up to #16 - same thing: when dhcp server works through relay, conflict detection feature completely shuts it down. Same messages in other announcement threads since 6.44. Have You seen them?
And one small request: when adding new features or changing the way existing works, please consider not to enable new functionality by default, unless it is absolutely necessary. I believe that not only me expect that upgrading to long term stable version won’t break the things, that’s already working.
If You’re interested, I can provide log files.
Thank You.
I have something very strange when upgrading to 6.44.6
I installed packages and log says that they are installed
After reboot, Mikrotik says they are not
But in packages I see TR69 is 6.44.6 version but rest is not?
This is the second CCR that has this problem. How to solve this?
Remove tr069 package, then manually upload the new packages (not the bundle) you need.
Reboot, and you are good to go.
Ping utility failed after some success pings. It just write “Running” and do nothing. It crashed after some ARP pings and choosing some options like “Interface”, “TTL”, etc.
Issue is actual using Winbox, web interface and console too.
Logging in with another user doesn’t help.
Logging in from another PC doesn’t help.
MikroTik CCR1036-8G-2S+
software: 6.44.6
firmware: 6.44.6
What to do, experts?
If it causes your router to crash, then don’t do it?
Jokes aside. If it is an issue then make a supout and e-mail it to support like detailed in the opening post.
But if this is unrelated to this specific version you should really make a new thread, or again e-mail support with more specifics and reproductive steps.
Anyone else using RB 3011 on 6.44.6 that shows the wrong link up time? Viewing the router through winbox ver 3.18 - 3.20 on Windows 7 and windows 10 computers. Viewing Last link up times on the Ethernet interfaces and even the PPPoE client interface shows link up times of the future. Right now its showing for " Last Link up time: Feb/23/2020 18:45:14 " on the PPPoE interface. Another router has Jan 8th for Eth 10 interface.
I’m not sure where the the link up times are calculated. But before anyone asks about the right time in the router and my computers, indeed the time is correct, the timezones are also correct. The link up times can also be different depending on what computer is used. One windows computer has the right link up time, the other computer using the same version of Winbox, doesn’t.
This is a known “feature” of winbox.
Can you fix Meta Router for install openwrt asterix version it does not allow install via image in latest version there is some bug .
thanks
Icko
New version 6.45.8 has been released in long-term RouterOS channel:
http://forum.mikrotik.com/t/v6-45-8-long-term-is-released/136469/1
